Question about Philips PD700 7 in. Portable DVD Player
Philips 7 inch portable DVD player metal spring that allows the door for the DVD to prop up
The DVD player's spring came off and I have no idea how to put it back in so that the door can come up by itself when you press the side button for the door to open. The door no longer comes up without me trying to get it up myself. How do I put the little metal spring back, so that it works on it's own again?
If someone knows how to fix the spring please let us know. The door came off and the spring popped out but i dont know where the spring goes for the door to pop back open. The open button is NOT what is wrong. Its just the spring that goes in crack on top part of opening where the door is. Tried several things
Posted on May 02, 2012
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Posted on Mar 28, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
  • 4 Answers
SOURCE: Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Posted on Dec 11, 2009
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
How to i make the secreen not be a negative color
Coby TFDVD9952 9" Dual Screen Tablet Portable DVD Player
www.bhphotovideo.com/.../Coby_TFDVD9952_TF...
B & H Photo Video
Rating: 2.5 - ‎2 reviews
Buy Coby TFDVD9952 9" Dual Screen Tablet Portable DVD Player features ... Get up to 2.5 hours of wireless use using the included li-polymer rechargeable battery ... Frame-by-Frame Playback, Not Specified by Manufacturer ... Color, Black.
Amazon.com: Coby TFDVD9952 9-Inches Portable DVD ...
www.amazon.com/Coby-TFDVD9952-9.../B004IZN3...
Amazon.com, Inc.
Rating: 3.1 - ‎17 reviews
The Coby TFDVD9952 9 inch Dual Screen Portable Tablet allows you to watch DVDs on two 9 inch widescreens (16:9) simultaneously. ... Color Name, Black ... When I bought a new one I decided not to get the DVD system factory installed.
Coby TFDVD9952 Car DVD Player - 9" LCD - 16:9 ...
www.overstock.com > ... > Mobile Video
Overstock.com
Rating: 4.5 - ‎4 votes - ‎$172.43 - ‎Out of stock
Get free shipping at Overstock - Your Online Home Theater & Audio Outlet Store! ...The Coby TFDVD9952 9" Dual Screen Portable Tablet allows you to watch DVDs on two 9" widescreens (16:9) simultaneously. ... This player has features not so common in this price range like Dolby Digital for simulated ... negative title.Missing: color
Jan 08, 2016 | Uniden COBY TFDVD9952 9 DUAL SCREEN TABLET...
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - ‎58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - ‎18 votes - ‎$59.78 - ‎In stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
Sylvania SDVD7027 7-Inch Portable DVD Player won't read DVD
The DVD player maybe faulty and it could be still under warranty.
Take it back to the shop where you bought it to have it repaired ot replaced under warranty.
Oct 22, 2012 | Curtis Sylvania Sdvd7027 7-Inch Portable...
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My portable dvd player PET704/05 isn't reading a
Overtime the laser pickup becomes weak until it can no longer play, try cleaning lens with a Q-Tip and rubbing alcohol gently, allow several minutes to dry. if no change! cheaper to replace the player.
Mar 09, 2012 | Philips Televison & Video
The spring came off of the disc door on my philips PET710 how does it go back on?
Dear Consumer,
We regret the inconvenience faced.
We would request you to share your contact details with us in order to get this issue resolved for you.
Thanks for your patience.
Regards
Philips Consumer Care
1800 102 2929
1860 180 1111
Jan 16, 2011 | Philips PET710 Portable DVD Player
Change region on Philips portable dvd player
Switch the player on
Open the tray door
Press Setup on the remote control
Select Audio
Press RIGHT ARROW
Press 2,1,2,2,2,5
Press LEFT ARROW
Press DOWN ARROW
Press 0 when the screen displays region code
Press Setup to exit
Enjoy
Mar 16, 2009 | Philips PET702 Portable DVD Player
Philips PD700 7 in. Portable DVD Player Logo
785 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
