Question about Intel D865GBF Motherboard
**System randomly hangs**
My system which has D865GBF motherboard hangs randomly, i have flashed latest BIOS version , replaced RAM, HDD and reinstalled OS but issue remains the same. Can you please suggest me what else could be done to fix the problem?? Need your advise very badly.....
  • 29 Answers
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intel**System randomly hangs** - reg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Posted on May 27, 2014
  • 781 Answers
Try cleaning all Fans and heat sinks include power supply then vacuum out case cleaning all vent holes and case fans also behind power supply
Posted on Oct 24, 2008
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Asrock P4V8+ freezes after ram checking
Try going into the BIOS and selecting safe or minimal settings/options save and reboot. If this works go back to BIOS and make changes one at a time until it may not work again, then you will know which option is causing the system hang ups. My guess is also your motherboard is SATA 1 capable (1.5
gbs) not SATA 2, in which you could purchase a separate controlller card for your HDD. Good luck.
Jul 02, 2009 | Intel D865GBF Motherboard
System time resets
Either the battery which has been replaced is faulty else it is not seated properly. Also after replacing the battery, clear the BIOS and then re-enter the settings starting with default settings and then changing it as required. If the battery was to work then this loss of date & Time won't happen every time. Also look for the Jumper meant for flashing the BIOS, I hope it is in its correct position............sodeep
May 02, 2009 | Intel D865GBF Motherboard
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
Unable to install XP sp2 on Intel D865GBF Motherboard
Maybe having trouble with a device, remove any pci or agp cards and usb devices, use built-in video until installed.
Set bios to defaults, make sure bios is latest version.
I have found this happens with a promise ultra-100tx2 and any nvidia video card.
May be a bad install cd, if you can boot it with a dos or win98 disk/CD, copy xp i386 folder to hard drive install from i386 folder on hdd by running winnt.exe
I have installed xpsp2 on about 10 d865gbf's and 2 days ago installed xp sp3 on one with no problems. may also be bad mobo.
Jun 28, 2008 | Intel D865GBF Motherboard
Intel D865GBF Motherboard- System gets Stuck very often
Does your System freezs before booting up? Try setting the BIOS to defalut. There could be a software related problem also. Try reinstalling the windows.Your hardware seems well match for the entire system(Provided all are ok) It was not clear where the system freezs.
Nov 24, 2007 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
196 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
