Question about Sony KDL46EX700 46 in LCD TV
Sony kdl-46ex700 factory reset - Sony KDL46EX700 46 in LCD TV
3 Suggested Answers
SOURCE: How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
Posted on May 15, 2009
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
Resetting my sony KDL-52V4100
Your tv probably has a remote. One of the buttons says "menu" or "settings". In one of those menues will be a reset to factory or default.
Feb 26, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
Reset tv sony kdl-37l4000
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 07, 2014 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
Kdl-46ex700 won't power on - standby LED blinks 7 times
There is a loose solder terminal, or a loose connection to any of the cables connected in between boards. Contact any service technician. For more information go to http://electronicshelponline.blogspot.com/
Dec 03, 2013 | Sony BRAVIA Televison & Video
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Hello! help please my sony bravia KDL-46EX700 red light blinks 5 times
IKR Error at power on 05 . Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 24, 2012 | Sony KDF-E55A20 55 in. LCD Television
Sony bravia model kdl-46z4100 has no sound. picture is ok.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Jun 11, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
How do I reset a Somy bravia KDL-52W4100 back to factory default settings?
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Jul 05, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
i+
5
VOL UP (+)
GREEN POWER button
Best wishes,
Mads
May 14, 2009 | Sony KDL-32S3000 32 in. LCD Television
Sony KDL46EX700 46 in LCD TV Logo
392 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
