Question about Atari 2600 Console
How to connect the atari 2600 to a hdtv - Atari 2600 Console
  • Atari Master
  • 424 Answers
Well I think that you need the lastest updated rf switch for an atari 2600 console and plug it into either a VCR or a DVD player then for it to work on this tv type.
4 STARS if this Solution is helpful.
Posted on Apr 20, 2012
drknow
  • 44 Answers
SOURCE: atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Posted on Dec 23, 2007
  • 5 Answers
SOURCE: 2600 atari
To connect your Atari to your TV, you'll need to get a "phono to f" adapter. These are available at RadioShack (part no. 278-255) for about $5.00 This adapter takes the phono plug from the Atari and changes it to a standard coaxial adapter. If your HD TV doesn't have an input for standard cable wires, you'll need to get yourself an RF modulator to switch the coax to RCA. If you have an old VCR with an unused cable input, that will work as well.
Posted on May 29, 2008
  • 18 Answers
SOURCE: Atari 2600 Console Power Adapter
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Posted on Jun 17, 2009
  • 13 Answers
SOURCE: ATARI 2600
Not quite sure what your problem is based on your description. You should have a cable coming out of the console...a long, black cable with an RCA cable on the end. This plugs into the switchbox, which then connects to the TV (probably through a 300 ohm to 75 ohm adapter). Or you could also use a RCA female to F male adapter...that's the cleaner solution.
Now, if you don't have the cable coming out of the back left side of the console, someone has cut or removed it. You can add it back yourself though. Carefully open the console with a screwdriver, and on the circuit board on the inside you should see an RCA jack. Get an RCA cable and plug it into here and run it outside the console through the hole that the original cable would have ran through. Then attach as described before.
Posted on Jul 30, 2009
SOURCE: Atari 2600 does not have picture when turned on.
The signal is output at 56MHz or 60MHz depending on the channel you use. Normal tv is around 350MHz to 700MHz so you need to got to the bottom range to tune. Also check that the contacts of the game catridge are not black looking, if so clean with some alchol to remove the soot build up, this will make sure the screen is outputted in proper format.
Posted on Aug 08, 2009
I lost my power adapter for my Atari 2600 where can I get another one? (one of those big black box things)
That is kind of an important peice, thankfullly people are selling power adapters on ebay you can also find them on Amazon for around $10.
Dec 08, 2013 | Video Game Consoles & Games
What was the last game officially released by atari for the 2600?
Xenophobe in 1990 was the last game atari released for the 2600. However, 3rd parties have released games for the atari 2600 as recently as 2008 (Actionauts)
Jan 29, 2013 | Video Game Consoles & Games
Atari CX-2600 won't work on my HDtv
The Atari will not work on a HDtv, it was not designed to.
Mar 14, 2012 | Atari Video Game Consoles & Games
Wha tis the best and fastest online site to purchase atari 2600 console power cord and connector to TV
  • Those are the two place I recommend and they have just about, if not, everything.
  • Hope this helps.
Nov 02, 2011 | Atari 2600 Console
Tried connecting direct to both an LCD and older set using the coaxial lead straight from the console.Cannot get anything at all.Do I need an rf modulator or no.
Quite the opposite - The Atari 2600 sends a modulated RF signal over the cable, it needs to go to the ANTENNA port of the TV, and you need an adapter. On eBay, look for
ATARI 2600 RF TV SHIELDED CABLE + ADAPTER
http://www.atariage.com/howto/connect.html is a really good guide.
Nov 26, 2010 | Atari 2600 Console
How on the atari 2600 does does the console connect with the tv?
Hi Atari 2600 console us a old style cable called an RF cable and connects to the TV arial inlet. see www.gameoz.com.au as they stock this cable and gear
Sep 22, 2010 | Atari 2600 Console
Trying to find a plud/ adaptor for atari 2600
Lukie games sell atari 2600 ac adapters and atari 2600 joy sticks too.logo.png
Feb 28, 2010 | Atari 2600 Console
Output: 9V DC 500mA
Positive tip
Anubis
Jan 05, 2009 | Atari 2600 Console
2600 atari
Mar 28, 2008 | Atari 2600 Console
Atari 2600 Console Logo
448 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
Nikki  Mclean
Nikki Mclean
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
