Question about Kitchen Ranges
Platinum rangehood changing light bulb
Need to change light bulb
5 Suggested Answers
SOURCE: Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Posted on Apr 19, 2009
SOURCE: Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
Posted on May 14, 2009
SOURCE: How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Posted on May 22, 2010
witserv
  • 144 Answers
SOURCE: i need to find out the light bulbs relacements for
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Posted on Oct 19, 2010
How do i change a light bulb in rangehood
There should be two screws underneath to remove the panel that the light is in. It may have one on each side. Remove the screws and drop the panel. If this does not cover it, reply with the model number of the hood.
Mar 10, 2015 | Washing Machines
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
Nov 17, 2009 | Kitchen Ranges
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
2007 Jeep Liberty 3.7L engine
The Jeep comes with Platinum plugs from the factory.
And also a little secret-They are guarenteed from the manufacture for 1000,000 miles
Your Jeep should have Champion plugs in it.
Sep 03, 2008 | 2006 Jeep Liberty
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
