Question about Exercise & Fitness
My treadmill keeps speeding up - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
Dear Sir:
1) You must have some lack of adjusment in your sensor speed, adjust it, see the diagram attached.
2) Tight the wire from sensor speed.or the sensor speed is faulty
3)Adjust the Potentiometer. this is attached with some gear in the motor lubricate, with light oil.
4)your motor can be faulty.
5)The main motor board can be faulty.
Now I STRONG recommend to RUN YOUR calibration software that coming with your equipment, most of them the instruction is from the Hood of the motor, and follow the step. or user manual.This is for easy diagnose and Troubleshooting!
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 16, 2012
York treadmill t301 runs for exactly 20 mins and the E1 displays making motor cut out in this 20 mins keeping the speed at 10 the speed varies but clock stays the same ???
Treadmill Maintenance How To Lubricate Treadmill Belt LED Blink Patterns on the Control Board Treadmill
Follow this steps carefully, in order to fix it.
If the problem persist, time to REPLACE the Controller board motor., by new one or Rebuilt.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 14, 2017 | York Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My treadmill belt keeps coming off track and I've
see the video and adjust it.
However adjust the speed sensor, see the diagram, test for open, clean it, and tight the connector very well
God bless you0a0a53af-952c-4674-ada4-9b097bbb30b2.gifbd425e75-1369-48e2-9a91-0cb9443892ca.gif
May 23, 2013 | Exercise & Fitness
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to...
hi,
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Jan 01, 2011 | Proform iLog 750 Treadmill
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Feb 25, 2010 | Exercise & Fitness
What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
MESSAGE "ERROR SPEED STALL" KEEPS COMING UP
returned the machine and got our money back, thanks.
Jun 20, 2009 | Bowflex Treadmill Series 7
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
73 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
