Question about John Deere Garden
L105 model starts but will not stay running, getting gas.
Cleaned bowl, float and needle. RUns for 2-3 seconds and shuts down.
4x4papa
  • 14 Answers
SOURCE: Briggs Flo Jet carb floods and puts gas into the crankcase
This is a common problem. The needle and seat are prone to being held open from debris, old fuel (these days it only takes a month for fuel to start to go bad) and poor mower design. The weight of the fuel from the tank can be enough to overpower the float system with just the slightest "gumming" of the needle seat. Also, if it's equipped with an electrically powered valve on the bottom of the float bowl, this unit can outright fail, get gummed up a bit, or the electrical system have a problem and power is getting to this unit while switched off, leaving it open thus passing fuel. Most likely, replacing the needle and seat, giving the carb a good cleaning will solve your problem, however if there is damage to the seat from age or debris, just install a 2 dollar in line shut off valve available at most retailers. Then just turn the fuel on and off manually. Cheap fix. 2. Drain the oil from the engine, refill with new oil and just a oz. of atf (automatic trans fluid). Crank the engine with plug wire disconnected for 30 sec or so, then connect the plug wire. Start the engine, but only let it run near idle for a minute or so. Drain again, letting the crankcase "air out" with all plugs\dipstick removed. Remaining fuel will evaporate. Refill and your off and cutting......The ATF is a detergent of a type and will help to collect the fuel from the surfaces inside the engine. It's important to note the fuel will have washed any lubrication properties from the oil, and damage to the journals and other surfaces can happen if the engine is run too long. Usually following the above procedure will limit damage and the engine should be good for many more seasons. Good luck! Papa
Posted on Nov 15, 2008
libaredneck
  • 119 Answers
SOURCE: my john deere 345 shuts down while running.
check the tank for debris blocking fuel outlet. also change fuel cap as it could be pulling a vacuum on the tank.
Posted on May 05, 2009
  • 124 Answers
SOURCE: model no. 31as6fef729 544332 ser.no.11235B80204
This is a good time to remind everyone that you should not leave fuel in equipment that is not used on a very regular basis. More than likely your carburetor is gummed up from the old fuel. This can happen in less than 30 days much less 2 years.
To properly clean a carburetor you need to remove the carburetor and purchase the correct kit for the rebuild. Disassemble the
carburetor carefully making notes where each part goes. Once you have the carburetor disassembled clean it by soaking it in carburetor cleaner for a few hours. Use anned aerosol automotive carb spray cleaner to fill a small glass jar with enough cleaner to submerge the carburetor. Use a jar with a metal lid so you can gently agitate the solution occasionally to make the process more effective. You need to allow the carburetor to soak as long as it needs to remove all visible deposits. After the carburetor is cleaned allow it to dry and reassemble.
Posted on Sep 20, 2009
mowerman1857
  • 389 Answers
SOURCE: Carburetor problem on Craftsman 14.5 HP B&S
The switch you are talking about is an anti-after-run solenoid. It shuts off the fuel flow when you turn off the key switch.
To check its operation is easy, turn the key on and off a couple of times and listen for a click, if you don't hear it, hold the switch between your thumb and forefinger to see if you can "feel" it click on and off.If you neither hear or feel the switch working, you will need to use a test light or meter to check to make sure it is getting voltage to it to make it operate.
If you just recently filled up the tank, it is possible that you have gotten some contamination (dirt or moisture) that has gotten to the carburetor. You will need to remove the float bowl to check this. You will need a very thin 1/2" wrench to remove the solenoid (electrical device) from the bottom of the carburetor to get the bowl off after you unplug the wires from it. Use some sort of small tray or cut off the bottom of an oil container or whatever to catch what is in the bowl to inspect it for contamination.
If you have a plastic in-line fuel filter look at it at its lowest point to see if there is any water in it. Water will look like a seperate bubble within the gas and floating at the bottom of the gas. Before removing the float bowl you might want to rig up something to plug or pinch the fuel line to stop the gas from flowing out of the tank while you are working on it
Posted on Oct 25, 2009
mickey813
  • 472 Answers
SOURCE: Tractor starts then shuts off, smell flooded
ck the seat saftey swicth thay go bad
Posted on Feb 21, 2010
I have a 2003 honda cr 250r 2 stroke,It will not kickstart,you can bump start it and it starts right up and runs really good.when you try and kick it it leaks gas out of the carborator.
Usually, a leaking carb is because either the float is set too high, or there is some crud stuck between the float's needle valve and it's seat.
Either one will not allow the float/needle valve to shut off the flow of gas when the float bowl get's full.
This should be your carb:
http://www.bikebandit.com/houseofmotorcycles/2003-honda-cr250r-carburetor-02-03/o/m2194sch305112
The floats are the 2 large square items on #5 on the illustration.
Item #3 is the float needle valve.
Item #4 is the needle valve's seat.
Jan 01, 2014 | 2003 Honda CR 250 R
Toro 20624 mower runs rough
Remove float bowl from carb. Ensure gas flows with float hanging down. Ensure gas flow stops with float pushed up.. Remove float and meter needle. clean passage way were meter needle is inserted with a bread wrapper wire, with 1 in of plastic peeled off it, wire should be observed behind choke flap when fully inserted thru passage way. Replace float and meter needle. Clean float bowl. Observe float bowl screw, look to see if it has a hole thru it, if so clean with wire. Reinstall float bowl. Try to start.
Jun 17, 2012 | Toro Garden
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
CRAFTSMAN 20" MULCHING MOWER MODEL
You have to take the bowl nut off he bottom of the bowl and clean it with a small wire or torch cleaners. Try not to allow the bowl to drop off the carb, the float drops down and the needle might come off the float.
Mar 11, 2011 | Craftsman Garden
Mower starts after priming, then quits. new sparkplug, air filter etc. cleaned bowl still no luck. cleaned out orifices in bowl screw. nothing. Suggestions?
Evan though you cleaned the bowl, the float isn't "floating" correct in the bowl to raise the needle for gas to flow into the carb. The float and needle can be replaced. When you prime an engine the gas shoots straight to the carb. As when the engine is running the floating goes up and down to raise the needle for gas to flow.
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Colman Powermate Generator will not stay running
This overflow can be caused by:
1. The float sticking
2. Gas inside of the float air chambers
3. The needle and seat have debris in them or a r damaged.
It is not a difficult fix but it does mandate removal of the carburetor float bowl.
You could probably do this yourself. It is much easier if you place the generator on a high work area so you can see the float and needle once you have the float bowl removed. Just make sure you do not drop the float assy so far that the needle comes out of the seat unless you have to remove the hinge pin SCREW for the float to clear the debris near the needles' pointed rubber head.
Thanks for using FixYa
Kelly
Mar 22, 2010 | Coleman 1850 Watts Generator Each...
I have a '74 dt-175. Was running fine.
loosen off the screw that you tightened up, sounds to me like the needle and seat valve is dirty, you will need to take the carb apart and either clean it well or put a carb kit in it.Very inexpensive and your carb will work much better. what is happening is the needle and seat are sticking and causing the carb float not to work properly, the float stays down and the carb continues to fill with gas, causing it to flud out.
Aug 13, 2009 | 1974 Yamaha DT 360
Riding lawn mower keeps flooding
It sounds like the inlet needle seat is not closing all the way,allowing fuel to overfill the carburetor.The inlet needle seat may have dirt in it.You will have to remove the carburetor bowl and check for dirt or debris in bowl,if so remove the float assembly and check for a peice of dirt between the inlet needle and seat.If there is none you may have to replace the carburetor or rebuild it with a carburetor kit.You should also chang the engine oil because the overfilled carburetor drains to the crankcase,filling it with fuel,check the oil level and see if it is high,that would indicate fuel is in the oil.Hope this helps
Jul 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My mower will run for a bit then start dieing
Sounds like there may be trash in the carb. when the gas bowl is full it runs until the gas runs out then it dies. Take the breather off get it started and then put you hand over the intake on the carb. sometimes this will allow the trash to be sucked on through do this several times take your hand off before the motor shuts down and then do it again until you clear it up. If this does not fix the problem you can take the bowl off the carb an see if it is getting fuel with the float hanging down this opens up the needle valve to let gas fill the bowl. there should be a steady stream of gas coming out. when the bowl fills up the float floats up and closes the needle valve. If there is not a steady stream of fuel coming out with the float hanging down with the bowl off you may have to remove the float and needle valve and clean out the needle valve jet with something like a sewing needle. If you are getting gas steady and fire to the plug it should run.
Jun 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
49 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
