Question about Kenmore 6000 BTU Single Room Air Conditioner
My air conditioner stopped working.
I just installed the unit in my window and after two day's it shut off and wont turn back on. I cleaned out the filter and checked the outlets and still the air conditioner will not turn on. What can I do? It was working just fine, then nothing.
  • sunil kumar Feb 08, 2008
    I washed back coil of my A/C, incidently water entered into electronic circuit box and with a tripping sound A/c stopped functioning, I replaced fuse but not working.
  • sunil kumar Mar 13, 2008
    Water entered into the electronic control box to my 1.5T LG window A/C. Fuse blows when I switched on. I dismantled control panel replaced fuse. But every time fuse blows in same manner. kindly guide me with a schematic wiring connection, may be I am doing wrong connection. If the wiring connection is write what could be the possible reason to blow fuse everytime.
    New Friend:
  • 163 Answers
Lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Posted on Aug 11, 2006
  • 3 Answers
I bet it's broken.
Posted on Jul 05, 2010
  • 3,230 Answers
The things to check are 1 circuit breaker for outside unit...2 capacitor on on outside unit could be bad...if it is swollen or is oily it is bad...3 bad contactor ....if the inside unit is running there should be a buzzing noise on the outside unit..this would be the the contactor energized..if it is buzzing then 1 no power 2 bad capacitor.... if it is not buzzing 1 bad contactor 2 low freon pressure switch could be bad(was it coooling good before it quit coming on ) if yes then low freon will not be the problem 3 broke thermostat wires close to outside unit...
Posted on Jun 05, 2009
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Getting an E1 error message..wont start
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
MY WINDOW UNIT JUST STOPPED WORKING AND NOW IT IS READING E1. HOW DO I GET IT TO WORK AGAIN?
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
A/c runs 1-2 hours then will not go back on for a day
Sounds like the unit is shutting of on thermal protection. Try removing it from the sleeve and take it outside. Wash it out good with a garden hose. If the problem persists, there is likely a problem with the refrigerant.
Jul 13, 2010 | Frigidaire FAC126P1 wall/window Air...
Air conditioner unit outside, fan not going but air is coming out of the vents. The thermostat is on 50 degrees. If it is shut off for a while and turned back on it will turn on but after and hour it will...
is the fan out side running when you are getting cool air? IF so check the out door coill is it clean, If not the fan could be over heating because it is pulling to hard. you should be able to feel the air 2' above the unit.
Aug 06, 2009 | Goodman CKL24AR24 Air Conditioner
My unit wont power on
if under year old you get anther if not make sure it is clean front filter and the back coil. turn it on with out the remote. is blowing the plug breaker.the plug breaker might be bad, see if still lit?
Jul 05, 2009 | Whirlpool ACQ108XL Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
1,606 people viewed this question
Top Kenmore Heating & Cooling Experts
1STHVACMAN
John Tripp
John Tripp
Jay Finke
Jay Finke
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
