Question about LG Washing Machines
Lg wd-8016c oe error message
Front loader
buffalonyman
  • 1865 Answers
SOURCE: MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on May 06, 2009
  • 905 Answers
SOURCE: top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Posted on Sep 15, 2009
SOURCE: door wont open on LG WD-8016C
mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
Posted on Aug 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: the front loader for lg washer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Door wont open on LG WD-8016C
Jan 31, 2010 | LG Washing Machines
Top loader door wont open
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Washing machine front loader has OE error code
Mine did the same and there was a 20 cent piece in the drain filter which is located at the bottom front left hand side you take off the cover - beware that a lot of water may come out - have towels ready. or your outlet pipe may be blocked. OE is a draining error message
Aug 22, 2009 | LG WM-2277HW Front Load Washer
May 06, 2009 | LG WM2277H Front Load Washer
The front loader for lg washer won't drain
Mar 29, 2009 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
73 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
