Question about Rockford Fosgate Car Audio & Video
How to bridge a 1 channel 1000 punch 55amp - Rockford Fosgate Car Audio & Video
  • 356 Answers
You can not bridge a 1 channel amp. Bridging is when you combine the output of a bridgeable two channel amp into one channel, typically to power a sub woofer.
Posted on Feb 13, 2012
3 Suggested Answers
  • 323 Answers
SOURCE: the amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Posted on Feb 10, 2009
jdinse
  • 74 Answers
SOURCE: hey i was wondering on the model punch 325.1
the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
Posted on Jun 08, 2010
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
How do i bridge a 150.1 punch amp
This is a 1 channel amp and can not be bridged. It is rated at 75W X 1 channel at 4 ohms and 150W X 1 at 2 ohms.
Feb 13, 2012 | Rockford Fosgate Car Audio & Video
How would u bridge 2 fosgate punch hx2 to this technique ICBM 9550 2600watts
  • Hi, I can help.
  • As I look at the manufacturer specs and recommendations this amp is not brigable. I figure I would tell you so you did not ruin it.
  • When you bridge you turn 2 channels into 1 channel. This is already a 1 channel amp. Bridging would ruin that amp quick.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Performance Teknique ICBM-9550 Car Audio...
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
Can you bridge the vega 124 or just use 1 channel on a punch 400x4
Good and bad news you can bridge the speaker it will make a 2 ohm load pretty hard on an amp but the Rockford can take it if you dont over drive it Bad news 400x4 will only go to 2 channels but should sound pretty good hope it helps
May 10, 2010 | Cerwin Vega 124 Car Subwoofer
Here are the important concerns:
The power rating of the speaker(400W) should be 25% HIGHER than the maximum output of the amplifier BRIDGED. (Amp bridged output 200W - OK!)
The amplifier will get twice as warm running the speaker when loud.
The impedance of the speaker can be no less than 4 ohms when the amplifier is bridged. (Yes, this speaker is 4 ohms - OK!)
Your punch amp is capable of running TWO Cerwin Vega 124s, bridged.
Apr 02, 2010 | Cerwin Vega 124 Car Subwoofer
Amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Punch 401s amplifier
hey mate try putting your positive on one channel then put the negative on the other channel. So plus on 1 channel an negative on the other channel hope that helps mate if any other problems let me know romz08@hotmail.com enjoy
Mar 13, 2009 | Rockford Fosgate Car Audio & Video
How to bridge a punch 3001 car amp
You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
