Question about PANDIGITAL Digital Book 843967071153 Tablet PC
My pandigital keeps restarting over and over again
The screen comes up and says that it is booting but then the screen goes black and does the same thing over again.
3 Suggested Answers
  • 343 Answers
SOURCE: i just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
Posted on May 13, 2011
I had same problem-charged it, and the ereader would flash on, blink and turn off. Tried charging it several times and even tried to use it whilst charging. It went totally dead and couldn't even get it to power up.
I reported to Pandigital and they want me to ship to them for 3-4 week replacement. Needed it now for travel, so bought another. at Bed, Bath & Beyond. It had same issue so I took it back to BBB and got a third one. SAME PROBLEM!
OK - insert a few swear words here - turns out I was trying to charge the thing through the headphone jack on the bottom. The charging port is on the left side.
I've charged this thing before several times. What the ***(#@ happened to my mind!! Cannot believe I went through all that and now I have to cancel my support ticket and hopefully return the now extra Novel to BBB.
So, check where you plug in the charger...
Posted on Jun 12, 2011
My galaxy tab A keeps booting on start up like it keeps showing Samsung and keeps repeating? How do I fix it?
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
Nov 04, 2016 | Samsung Tablets & eReaders
How do I turn on my pandigital supernova tablet?
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | PANDIGITAL SuperNova
Wont boot up
Re-install the operating system.
Oct 14, 2015 | Tablets & eReaders
My first generation iPad appears to be totally dead. When I plug it into charge all I see is the flashing Apple. Is there a way to get the system going again ?
The battery in it has most likely expired and may cost more than a new iPad to replace. A voltmeter across the charger or a friends iPad may be useful to test your charger works ok.
Oct 11, 2015 | Apple Tablets & eReaders
My pandigital has a box pop up that says "Sorry" The process android.process.acore has stopped unexpectedly. Please try again. Force close." It just keeps popping up and won't let me do anything....
Try holding down the power and volume up buttons down for several seconds to try and soft reset your device. Power down and restart it. You don't state your model of Pandigital-that makes it hard to determine exact reset procedure. Also look for a small hole on the back or sides of the device, into which you can push a toothpick or paper clip to push a reset button (check your manual for location and reset procedure for your device). You can also try powering down, then press the volume down button and while holding that down, press the power button to turn the device back on. The error indicates a major problem with the base android software - did you recently upgrade software or install some new app? If it was a new app, try uninstalling it and see if the problem goes away.
Jan 02, 2015 | PANDIGITAL Novel Color Multimedia eReader
What do i do when i have a 7 inch pandigital tablet/ereader in white and it has the button that pops open with an error that says force close and wont let me get passed that button because it keeps po
this is about the worst tablet you can ever buy
in the future spend more than 80 bucks either way here is the help you need to fix it it is called a hard reset
How to hard reset Pandigital Novel 7 to Factory Default Setting Reset Pandigital Novel 7 to factory default setting you will lose all of your sms and apps,so you must back up your apps and sms.
These steps will show you how to hard reset Pandigital Novel 7 to factory default settings:
First, try this:
1. Go to main home screen, press the menu button.
2. Choose the Privacy
3. Press Factory data reset.
4. Read the disclaimer, then Press Reset.
5. Last,press Erase everything.
6. Restart the Pandigital Novel 7, you will see the phone as a brand new phone.
Feb 16, 2018 | PANDIGITAL 7270FW Tablet
PANDIGITAL Digital Book 843967071153 Tablet PC Logo
472 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
tosin_christ
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
