Question about Kenwood Audio Players & Recorders
Cooling fan is not turning on. Kenwood Kr V8060
5 Suggested Answers
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 222 Answers
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Posted on Jun 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
  • 1575 Answers
SOURCE: Kenwood kr-720 service manual
Hi Vanpost941,
You can download the manual in pdf by clicking here. or here.
Hope this helps.Thanks!
Please rate this answer.
Posted on Nov 24, 2011
I have a KR- V8060 that will not power up. What should I do?
Check the fuse inside it first if you don't want to send it for repair at a radio shack.
May 14, 2016 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Kenwood kr-v888d after "ON", through 3sec.
May 18, 2011 | Kenwood KR-V5580
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
Ppower on then standby problem Kenwood KR-V8060
This fault may be similar to a Harmon Kardon AVR1550 fault I recently encountered. I did all the usual checks e.g. testing for presence of DC on speaker outputs etc. but all seemed fine, then the fault cleared! Next day it re-appeared and attention was (falsely) given to the protection circuits as the amplifier circuits themselves were considered to be in order. The HK uses both voltage and current protection circuits and it was discovered that the current protection circuit was operating. Eventually the fault was found to be one of the 0.39 Ohm 3W metal oxide resistors that had gone high in value on the left hand channel. Of course your amplifiers fault may not be due to this but the reason for going into standby would probably be the same i.e. due to amplifier protection circuits operating. You need to check out all the output devices and those resistors on every channel, even surround ones you may not be using. Hope this helps.
Nov 01, 2007 | Audio Players & Recorders
66 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
