Question about Rockford Fosgate Car Audio & Video
How do i bridge a 150.1 punch amp - Rockford Fosgate Car Audio & Video
  • 356 Answers
This is a 1 channel amp and can not be bridged. It is rated at 75W X 1 channel at 4 ohms and 150W X 1 at 2 ohms.
Posted on Feb 13, 2012
3 Suggested Answers
SOURCE: punch 401s amplifier
hey mate try putting your positive on one channel then put the negative on the other channel. So plus on 1 channel an negative on the other channel hope that helps mate if any other problems let me know romz08@hotmail.com enjoy
Posted on Mar 15, 2009
  • 51 Answers
SOURCE: I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Posted on Sep 25, 2009
It was hooked up to a 2 or 1 ohm load now it dont work
if it was hooked to a 1 ohm load its most likely fried. what watt were you trying to push?
May 29, 2011 | Rockford Fosgate 25 To LIFE Punch 150...
Amp shut off has power and grond and remot but only my p550 shut off fuses are ok and all other amps are wourking
how many subs are you running on this amp, and how many ohms are they. if the are bridged, try hooking up stereo and see if the problem still occurs. make sure your scrape off all the paint where the amp is grounded to the frame which should be less than a few feet. i'd also recommend running at least a 4ga wire for both your power and ground.
Jan 30, 2011 | Rockford Fosgate Punch P550.2 2-Channel...
Can you bridge the vega 124 or just use 1 channel on a punch 400x4
Here are the important concerns:
The power rating of the speaker(400W) should be 25% HIGHER than the maximum output of the amplifier BRIDGED. (Amp bridged output 200W - OK!)
The amplifier will get twice as warm running the speaker when loud.
The impedance of the speaker can be no less than 4 ohms when the amplifier is bridged. (Yes, this speaker is 4 ohms - OK!)
Your punch amp is capable of running TWO Cerwin Vega 124s, bridged.
Apr 02, 2010 | Cerwin Vega 124 Car Subwoofer
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
How to bridge a punch 3001 car amp
You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Dec 03, 2008 | Rockford Fosgate 25 To LIFE Punch 150...
Rockford Punch 550.2 amp wont play
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Apr 16, 2008 | Rockford Fosgate Punch P550.2 2-Channel...
Car Audio & Video Logo
98 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
