Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai RHFE 1004fa making a horrible squealing noise
I have the Rinnai RHFE 1004fa. It is making a hideous squealing noise when the heat is blowing. The problem started as an intermittent squeal that wasn't nearly as loud. Now it is all the time when the heater is running and it is crazy loud. It's in my living room and it is driving me crazy. So crazy that I'd rather be cold. Here's a link to a video I took where you can hear it. Hold your ears!
SOURCE: Rinnai RHFE 1001FA
i have a rinnai rhfe 1001fa heater and when its real cold sometimes it will shut down all the lights go out and i have to shut it off then turn it back on and sometimes it still wont start and i will leave it of for a day or two then try it and it will work it seems to act up more when its colder i am running it this fall so far no problems this unit is around a 1994 or so and has not given any trouble till this started last winter
Posted on Sep 19, 2007
  • 1420 Answers
SOURCE: Rinnai RHFE 1004F Error code 49
A 49 error code is caused by the pressure switch either not proving or a bad component. Check the hose attached from the plastic elbow located behind the heater going to a small square pressure switch found inside the heater. It may have come loose or a mouse may have taken a bite out of it. Also while you are behind the heater, pull off the hose that looks like a vacuum cleaner hose and run the heater with it unattached. If it runs, you have a blockage in the vent. If not, take a flashlight and go outside to the vent. Look down the center pipe for any obstructions. If it still does not work, you may need a new pressure switch.
While the front panel is off the heater, cycle the heater to attempt a start. You want to make sure the blower turns. If it does not, check the wire connections to it. You may be looking at a bad blower. If it is turning but still does not start, we are looking at a bad pressure switch.
Let me know what you find, I may have a switch or blower motor that you can purchase.
Posted on Nov 01, 2007
SOURCE: rinnai 1004fa
this link is not working
Posted on Feb 13, 2008
  • 12 Answers
SOURCE: I'd like information on the reliability of Rinnai
Beside the filters in the back, no they don't require much. After 8 years of installing and servicing these units, I haven't found a unit yet that was running faulty due to lack of service. Would recommend a cleaning of the burners about every 3-5 years. Rinnai recommends cleaning the unit with compressed air through the front grate annually...but that doesn't require disassembly
Posted on Sep 14, 2009
Testimonial: "Thank You, I have installed 2 Rinnai 1004FA furnaces but haven't had them long enough to require service. Both heat 1000 sq ft houses in the NE."
  • 33 Answers
SOURCE: My Rinnai RHFE-1004FA 38,400 BTU Energy Saver has
Sounds like combustion fan or room fan get unit serviced
Posted on Jan 16, 2010
Rinnai Energysaver 1004fa making a horrible squealing noise when it gets cold. It's usually only when it drops below 10-5 degrees F. It still seems to run fine, but the noise is driving me nuts. Is...
Hi Doug,
I have not seen this problem and my suggestion would be to look at the bearings in the combustion fan motor.
This motor is located in the lower right hand side of the unit and can be seen once the front cover is removed.
You can watch and listen when the unit starts up from a cold start and this should confirm where the noise is coming from.
This part is not easily removed and I suggest an experienced service person should perform the removal and replacement if this part is causing the noise issue.
if this does not help please contact me again
Good luck
Jan 08, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Newly installed rinnai rhfe-1004fa gas heater will not start up
I don't know what's the matter with fixya site it's getting to be a real pain in the as>
Dec 07, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I am not sure which model we have but it is like this one but about 8-9 years old. It made a large sound then stopped working. it still makes a noise as if it is working however it is not blowing out any...
Rinnai makes a good product and certainly if it's making a noise, it should be serviced and checked by an authorized Rinnai service technician. That way, you can determine whether the cost of repair ot ways the purchase of a new one. A good rule of thumb i, if the cost exceed 50% of the cost of a new one, it's wiser to purchase a new one. Which will have higher technology and a new warranty.
May 10, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at
Feb 02, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Vibration/noise from convection motor and fan. Had them replaced and still have the noise.
If you never had the noise amdit is still the same noise, mybe they didnt
replace it afterall.
Turn the fan speed from hi to Lo and see if that does not do anygood
Jan 20, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Using the rinnie as a major heating source for an older home
The smaller the vent the better. A Rinnai may heat an area just fine but a whole house is pushing it.
Dec 17, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai monitor heater 1004F
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004fa
page 35 of the following: hope this helps :)
Dec 24, 2006 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
120 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
