Question about Plantronics CS70 Wireless Headset
Headset has static
Plantronics model CS50 worked fine yesterday. nothing has changed since then, and today i pick it up and get static when i have a dial-tone. i swapped out phone cords, tested the alternate jack on the phone, even plugged the handset into the headset jack to cross-check. handset worked fine. the headset functions correctly until i get a dial-tone. dial tone is nearly drowned out with static.
  • JCooper Dec 19, 2008
    Same thing here, with a CS70. Also lifter works fine to pick up the phone (but the static is deafening), but when the earpiece button is pressed to hang up the phone it does cut the connection but doesn't drop the handset.
  • 32 Answers
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Posted on Apr 28, 2009
How do i fix my phone, it rings, but i cannot dial out and there is lots of static and buzz when i pick up the phone
Do you have other phones on the same line?
Are they clear or do they have the static. If it is a telephone company old copper line and it happens on all phones it maybe a Telco problem.
Sep 17, 2014 | Uniden HO 200 Home Organizer Phone (HO200)
I CAN ADJUST VOLUME ON HEADSET, BUT I DONT HEAR A DIAL TONE OR VOICE THRU HEADSET
You don't specify which headset that you have. I would need to know which one and check all the connections to know why you aren't hearing a dial tone.
Here are a few things you can try -- try checking all the connections, unplug and replug back in, make sure that they are in the correct slot.
If it is a wireless headset say like a CS50-CS55 there is a 1-4 on the side, check to see if the #1 is in a 3 O'Clock position.
Is this a computer headset, wireless, corded, bluetooth, MP3?? Can only give recommendations of things to try.
Good luck from Headsets Direct!
Aug 24, 2011 | Plantronics Radio Communications
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Jun 10, 2011 | Plantronics S12 Headset
Our new clarity XL40D phone is not working. Yesterday I could make & recieve calls & the booster was working. Today I noticed the DC adapter end was not snapped all the way in & that was...
Hi Bonnie,
I'm sorry that you are having difficulty with our phone. If you are still experiencing trouble, please call us at 1-877-LOGIC24 (1-877-564-4224). We will be able to easily test the phone remotely and determine any potential issues. If you are more comfortable with email, contact us at: claritycs@plantronics.com.
the Clarity Service Team.
Jan 29, 2011 | Clarity Lands Phones
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
No Program folder for Plantronics application / driver.
The CS50-USB from Plantronics extends wireless freedom to your softphone. It’s the first wireless headset for VoIP applications with remote call detection and answer/end capability via PerSonoCall software (built-in).
Enjoy yourself without bothering about software!
Jan 05, 2009 | Plantronics CS50-USB Professional Headset
CS50 headset with lifter not beeping when away
It is the handset lifter that actually picks up the ring tone from the telephone, and not the CS50 itself. The first thing that you want to do is make sure that the ring tone or ring volume didn't change on the phone, because this could throw off how the lifter "hears" it. Also, I'm not sure which lifter your user has.. if it's the larger HL1 (this one has a base that the phone sits on), there is a sensitivity adjustment on the back of the lifter. If is the smaller HL10 which sticks onto the phone (and should be positioned over the speaker grill where the ring tone comes out of the phone), the internal mic may have stopped working and that could be why it doesn't hear the ring anymore. If you have the HL10, you can try using a ring detector cable, this is a little accessory that should have come with your lifter (it looks like a wire with a small speaker on the end of it with double-sided tape). Plug this into the back of the HL10 (there are 2 jacks back there but it will only fit in one, you may need to remove the rubber plug), then stick the little speaker over the speaker grill on the telephone. If this doesn't work, you may need to replace the lifter. Here is a link below with a picture to take a look at the ring detector. Plantronics 46780 01 Ring Detector Cable PLX Headsets Direct
Aug 25, 2017 | Plantronics PL-CS50 Professional Headset
Plantronics CS70 Wireless Headset Logo
1,055 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
