Question about Acer Iconia Tab A50010S32u Notebook
My tablet is muted and I can't unmute it.
I an having problems unmuting my phone at times, it just goes on mute automaticly, i can hear them but they cant hear me
Does it show an icon, usually a crossed-out microphone, informing you that the call is muted? Or people just can't hear you?
You may have a broken microphone in the phone, it happens.
Mar 20, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
How To Unmute Sound
tablet setting icon gear shape has sound display option from ringtones to touch sound.And volumes,increase bar section on volume to maximum to enable sound in case it was disable.
May 09, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Unmute sound asus u52
sounds like a bad driver download the best driver for it from their site.
Jan 02, 2013 | ASUS U52F-BBL9 Laptop
How do i unmute my nextbook tablet
You mute/unmute with the volume controller on the right upper side of the tablet. If it's muted, run the volume all the way down to zero, at which point the slash mark through the volume icon will disappear. Then you can set your volume level.
Dec 23, 2012 | Tablets & eReaders
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
Aug 21, 2012 | Apple iPad 32 GB 3G Tablet PC
How do you unmute a toshiba tv
Check your remote control for its infrared emission. If the remote does work for half mute, an other press must make the TV to full mute, and an other press the TV should be unmuted. Check the remote with new batteries.
Jun 18, 2012 | Toshiba REGZA 47HL167 TV
My H710 is on mute - how do I take the mute off??
To mute or unmute a call on your Motorola H710 Tap both the volume buttons until you hear a mute tone.This will mute or unmute the headset during the call.
Hope you're satisfied with my solution.Thanks for choosing Fixya.
Jul 10, 2011 | Motorola Mobility H710 Bluetooth Headset
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
May 05, 2011 | Samsung Cell Phones
Acer Iconia Tab A50010S32u Notebook Logo
864 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
