Question about Samsung Dryers
Samsung dryer stops in mid cycle
The dryer simply stops after drying for 5-10 minutes. Stopping for a period of time will allow it to start again, but it will only run for a few minutes
exspert
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 1122 Answers
SOURCE: Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Posted on Oct 02, 2008
kachbibi1
  • 979 Answers
SOURCE: Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Posted on Jan 14, 2009
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
While drying the dryer stops running every few minutes.
Have you checked the hose and ductwork to make sure it's all clear? It might not be able to ventilate.
Mar 06, 2009 | Fisher and Paykel DGGX1 Electric Dryer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
478 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
