Question about Bobcat Miller 250 Welder Generator 907212 Or 907211
Miller 250nt with kohler engine will not idle down
It starts fine goes to full throtle and stay there
2 Suggested Answers
  • 4 Answers
SOURCE: how to separate the kohler engine from the
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Posted on Jun 26, 2011
What size motor came out on the miller blue star 2e welder
Depending on serial number, Miller started out with Kohler manual start, Kohler electric start, and then Tecumseh electric start. They ended the series with a Tecumseh OH160, miller part #070732. I have included the manual. https://www.millerwelds.com/files/owners-manuals/O424E_MIL.pdf
Sep 11, 2017 | Miller Welding Tools
85 HONDA ACCORD WONT STAY RUNNING UNLESS PUMPING GAS NOT EVEN FULL THROTLE
You have a single fuel injector in it right. Try right at the end of the gas pedal cable at the engine there is an electrical plug and a little device that goes around in a circle when the gas is mashed. That is the throttle position sensor. Try unplugging that and if there is no difference in the revving then the throttle position sensor is out. If that is not the problem, then plug your engine into a an onboard diagnostic reader. 85 is an obd1.
Feb 19, 2015 | 1985 Honda Accord
My welding machine will not idol down .Only stays in high idol. Why won't my machine idol back down when not welding? Yes I have the switch on run / idol lol 225 bobcat miller Kohler engine
Possibly the idler control circuit board. I changed out my fair share back when I worked on them. Also, check your idler solenoid. I can't remember if those pulled in to idle, or pulled in for high RPM's. May be something as simple as rust on the solenoid plunger.
Dec 15, 2014 | Welding Tools
My welding machine will not idol down. Only stays in high idol . Why won't my machine idol back down when not welding? Yes I have the switch on run /idol lol 225 bobcat miller Kohler engine
put 12 volts to the coil and see if it pulls in. Could be coil, idle module, ignition switch, or wiring. Get a 12v test light and trace it.
My tb516ec edger starts fine and ideol fine when the throtle is race it cuts out why does it stop runing when it speed up
Carb adjustment. Start with 1 full turn out on both low and high side. If it falls on it's face, then turn the low side out and additional 1/4 turn.
Sep 27, 2014 | Garden
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
94 Celica 2.2 starts and stays at 5000rpm!
check the exseleration cable from yr pedal to the throtle assembly most probably just sticky and got stuck, spray the spring on the pedal,cable(wher possible,usialy beginning and the end of it) the assembly on the throtle body that the cable gose 2 with some W40, that will most probably fix yr problem if note just open yr in take on the throtle body and clean it in side, than 100% yr problem will be solved. G/luck
Oct 17, 2013 | Toyota Celica Cars & Trucks
2006 Hawkeye sputters at full throtle. Take air boot and air cleaner off runs fine. put just air boot on it starts to sputter at full throtle. Not even the air cleaner just tube from carb to air clean
that might be the overflow tube and should not be hooked to anything, it's like a emergency drain for the carb and when you hooked it to the filter is pulling gas out of the carb at high motor speeds causing it to sputter .. jay
Aug 28, 2012 | Polaris ATV
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Bobcat Miller  250 Welder Generator 907212 Or 907211 Logo
311 people viewed this question
Top Bobcat Welding Tools Experts
Lawrence Oravetz
wadingriver
wadingriver
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
