Question about White Sewing 1730 Mechanical Sewing Machine
I received a new machine and was excited about the Quilt 'N Sew... I just watched the video and discovered my machine came without the Feed Cover Plate. I understand the video has many features a
New machine missing the Feed Cover Plate in the sealed plastic bag. How do I get one? Do I have to pay for it?
  • White Sewing Master
  • 7,365 Answers
Contact the place the machine came from & tell them the feed cover plate is
missing & ask them where it's at, that you need it.
Posted on Apr 12, 2012
  • I got your comment & it disappeared, I would still call big lots & tell them you bought a sewing machine & it didn't have all the parts it was suppose to & how that your going to have to buy one & see what they say.
    here are some places to check for parts
    sewingpartsonline.com
    sewusa.com
    sew4less.com
    premiersewing.com
    sewing-machine-parts-store.com
    also I see this sewing machine is under the catagory of
    white sewing machine also try
    singer for parts
    good luck
    Debbi
2 Suggested Answers
  • 1116 Answers
SOURCE: how do I disengage the feed dog so I can machine
If there is not a lever on the machine for lowering the feed dogs, check the manual for accessories to see if there is a darning plate than snaps over the feed dogs. There will be tiny holes in the face plate where the plate snaps into place.
In a pinch, you can set the stitch length to zero and securely tape an index card (punch out hole for needle) over the feed dogs.
Blue painter's tape works well as it does not leave a residue - I also use the tape as a guide when stitching long lengths that are too far from the fabric edge for any other type of guide.
Posted on May 07, 2010
I have machine MX3123 New Home - I lowered the dog feet - but it won't allow me to free hand quilt - what pressure foot do I need
You need a darning foot or free motion foot. They are shorter than standard presser feet, so they do not set on the feed dogs but hover just above. The additional space allows you to manipulate the fabric without interference from the feed dogs. (Be sure to drop the feed dogs or cover them with the supplied cover plate--whichever your machine uses.)
Feb 16, 2017 | New Home Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
How to Free Motion Quilt on Regular Sewing Machine
Feb 25, 2016 | Sewing Machines
Trying to free motion quilt with darning foot. No directions in small manual. Does any know if there is a user guide for all that this machine can do.
General instructions for using a darning foot to FMQ:
Put in a new needle, install the darning foot, then be sure to DROP the feed dogs. Then practice on a scrap quilt sandwich (made up of the fabric and batting you plan to use on your quilt). (You may need to readjust the tensions if your top or bottom threads are popping through to the other side.) If you've not FMQ'd before, practice, practice, practice. You need to get your brain in tune with your hands (much like you did in elementary school learning to write). It even helps to get a white board and practice making FMQ designs with erasable white board markers or a pencil and paper pad. A FMQ instructor told us that it takes 50-60 times before your brain and hands develop the coordination. The more you do it, the better you will get. When FMQing, practice moving your hands as smoothly and consistently as possible. If your hands jerk, your stitches will sew it. Also, practice using a consistent machine speed for even stitching.
Mar 29, 2015 | Sewing Machines
While trying to free motion quilt on my juki TL-98Q, it becomes very hard to move the quilt whenever I come to a seam. I have already turned the pressure foot dial to the lightest setting. I simply
I have never used a machine to free motion quilt. That said, I have had issues sewing over thick seams. Since your machine runs smoothly otherwise... I think it is the thickness of the seamed area that is causing your problem. It may be too late but you could try trimming your seams so the layers fabric graduate to full thickness. Or you could use a chop stick or popcicle stick to press down on the thickness as you guide the machine over the seam. I also suggest that you Fan your seam allowances where your blocks come together. You can see how that is done here. http://www.allpeoplequilt.com/videos/v/62207505/machine-minute-bulky-intersections-fanning-seam-allowances.htm
Mar 19, 2014 | Juki TL-98Q
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Quilt Sew Clever
If you need a different brand try brother sewing machines .Maybe your machine is not compatible with the capacity of your electricity.
Sep 17, 2012 | Sewing Machines
Why when i put the feed cover on i cant move the fabrice at all there is no room between the foot and the cover. i am trying to quilt together my quilts. thank you brenda g
I'm assuming your machine has a little plate you put over the feed dogs rather than a knob which disengages the feed dogs from moving to do free motion embroidery or something.
If this is the case there probably isn't enough room for your quilt sandwich under the foot.
You could try using a free motion embroidery foot rather than the regular foot with the feed dogs up and see if that allows you sufficient movement.
It would look like this:
It may take some practice still to get a smooth stipple if that is the effect you are going for.
You may find some other ideas on quilting websites to get around this problem or in a Yahoo group for quilters. I've only ever quilted in straight stitch using my walking foot so it feeds the quilt smoothly for me, never tried FMQ.
Oct 24, 2011 | Brother XL-5130 Mechanical Sewing Machine
Mygolden singer touch and sew wont feed the material
Does the feed dogs move at all?
If not soulds like a busted gear. Take the botom panel off and inspect the gears should be able to get some from a sewing dealer and replace them if your mechanical. watch a youtub video on timing a sewing machine and you will do great.
hope this helps
Mar 18, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
White Sewing 1730 Mechanical Sewing Machine Logo
79 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
