Question about Whirlpool Washing Machines
Whirlpool awo3761 wont rinse and spin
Whirlpool awo 3761 all programes work till it comes to rinse and spin pumps working ok and drum turns but wont go onto spin or rinse more than once it spins ok on delicate wash pls help
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
canbruce75
  • 1776 Answers
SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Posted on Aug 02, 2009
mnwarfield10
  • 452 Answers
SOURCE: Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Posted on Dec 30, 2009
SOURCE: machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Posted on Feb 18, 2010
My whirlpool AWO 3551 when you start a program, the drain pump runs for a while then the door locked light goes from solid red to flashing red and the pump stops, I have checked the motor brushes and...
I just tried looking your model up but the # you gave is incomplete. If your washer is a top loader and has a belt, my experience has been the mode shift actuator causes lid lock light to blink as you have described. That is a fairly inexpensive and simple part to replace.
Sep 01, 2017 | Washing Machines
I have a whirlpool AWO 3761 and it says " clean
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem!
BTW manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 12, 2011 | Whirlpool AWOE8748 Front Load Washer
I have a awo 3761/5/s model and it keeps coming up on the display fh and the lights flash what does this mean
Unfortunately there are so many abriviations that one cant keep up.(not standardised). Best thing to do is do a manual check. Switch water off and check the filter. Clean it. Next, do a check and confirm that the drain pump is free of obstruction and free to turn.(loose). Get motor to spin by selecting spin and see if it does. If all those checks work out, it should function.
Jun 05, 2010 | Whirlpool Washing Machines
My Whirlpool AWO3761/S Wont Wash Or Do A Full Spin But A Slow Spin Works Ok When I Start Any Program It Goes As Normal Starts Filling Rotates the Drum One Way Then Stops The Timer Clicks Like It Is...
Sounds like a problem with the door lock, door switch or the door switch actuator. Door lock is usually a single assembly with the switch. Check the pin on the door first. Model # is probably mistyped, won't come up, so can't tell anything specific.
Oct 13, 2009 | Whirlpool Washing Machines
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool AWO 3761/S
    Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
    May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
    Washing Machines Logo
    21 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
