Linear Tracking Turntable adjustments
I have a Carrera LT-120 Turntable that is working, but it is not dropping the needle at the right place ( at start and all other tracks )
  • Robert Rankin Feb 14, 2012
    Any idea on how to adjust it si it drops the needle in the right spot?
  • Robert Rankin Mar 23, 2014
    I took it apart and found the problem and fixed it. It is working "good as new"!
    Problem Solver:
  • 10 Answers
I have the service manual for the LT-120 which explains how to do that. There are explanations with diagrams, etc. that won't help without your being able to see them.
Posted on Jul 06, 2012
djproaudio
  • 515 Answers
SOURCE: problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 23, 2008
SOURCE: Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Posted on Sep 22, 2008
  • 42 Answers
SOURCE: turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Posted on Jan 25, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
djproaudio
  • 515 Answers
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
How do I fix the on/off switch on a Mitsubishi LT-22 linear tracking record turntable?
After long inactivity there should nothing be broken but probably there is only some oxidation in the switch that also had the long cam switches in tape and tape recorders sometimes, a canister contact spray can sometimes do miracles
Jul 30, 2017 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Set the Stylus Pressure/Tracking setting to 0.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
Hi! I've replaced my old stylus on a technics sl 20 (EPS 270 ED) by a tonar 757-DE elliptical, as it was recommended. The result is disappointing. The lows seem right, but the middle and higher range is...
You definitely want to make sure that your new cartridge is properly aligned for your turntable. This web site can help:
http://www.audiophilia.com/features/cartridge_setup.htm
If you don't feel that you are able to get it properly aligned by yourself, a local dealer should be able to help you with this for a small fee.
Mar 08, 2011 | Technics SL-BD20D Turntable
I need an illustration to install a drive belt for Panasonic SL-N15 model. This is a linear tracking turntable. I purchased a belt from a website - it is not a Panasonic, but they claim it will fit my...
That's right.
Here are some in-depth instructions.
Turntable-belts generally go from the spindle motor to the underside of the platter. The platter, or table tray, is the metallic structure which supports the record. After taking the platter off the turntable, a pretty self-explanatory process, look for the only large, circular "lip" on the platter's backside and wrap your belt around it. Make sure the band is flat, not twisted. Put the platter back in its original place and, working through one of the holes in the platter, pull the turntable belt to the far side of the spindle motor.
I hope this helps.
Jul 13, 2010 | Panasonic Audio Players & Recorders
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Turntable starts playing record middle 1st song
Jan 24, 2009 | Kenwood KD-291RC Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
Problem with technics SL-L20 linear tracking turntable
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 22, 2008 | Panasonic Audio Players & Recorders
341 people viewed this question
 Grubhead
Grubhead
