Question about Kenmore Refrigerators
NEW KENMORE NOT GETTING COLD ENOUGH
04662152000 Model #: 6215 KSN #: 3457408 3 DAY OLD Kenmore will not get COLD! Food in FREEZER has defrosted!!! Is warm in both the freezer and lower area.. just under 50 degrees.
  • 341 Answers
Is there enough room behind the unit to allow it to ventilate properly? Most freezers and fridges need a minimum of 6 inches between them and the rear wall to allow for the extracted heat to dissipate. SInce it is only 3 days old, I would suspect that there may be a defect if the rear clearance is not the problem. Have you contacted Kenmore's Help Line? It is 1-888-KENMORE (1-888-536-6673) Give them a call and see if they can help/
Posted on Feb 13, 2012
MNTECH
  • 1543 Answers
SOURCE: left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Posted on Nov 04, 2008
Sea Breeze
  • 4654 Answers
SOURCE: ed2shaxm freezer not working refrige side works
Need you to have a look at a few things inside the fresh food compartment. Also go to site listed below and enter model number
ED2SHAXML10 into the model search feature. This will take you to the page and on left side of page choose photo #11 controls. this is what I want us to focus on unless there is other symptoms not mentioned in your post. Part number 6 and # 9. Let me know, Thanks, Sea Breeze
Posted on May 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: frigidaire freezer cold, refrig in 50's.
Yes pull the refrigerator away from wall and feel top of the compressor. Is it too hot to touch? Are bot fans running. Straight wire the thermostat to see if it is causing this. The start relay and start capacitor may be the reason. Let me know by email you response because Fixya has not been notifying me of any ones response to my solutions. I just found you made a response. Sea Breeze
Posted on Jul 20, 2009
jvernice
  • 63 Answers
SOURCE: defrost cycle too long...freeze cycle about once
The defrost timer is correctly set for about 24 hours. The problem is that your not cooling properly. This could be due to low refrigerant, blocked (or non-functioning fans), dirty coils, etc.
Posted on Jul 28, 2009
toolkits
  • 1099 Answers
SOURCE: not keeping cold enough reading
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Good luck, Hope this helpout.....
Posted on Aug 07, 2010
Kenmore elite bottom freezer refridegerator error code er rf
you could call a repairman but if it is fairly old then buy a new smaller refrigerator the smaller simple ones seem to last longer in the long run .
Jul 17, 2015 | Kenmore Refrigerators
Hello! I have an old model Kenmore 21 CF. The fresh food part of the refrigerator (the freezer seems fine) is not cold enough. Last night at 11:30pm I turned it from setting 5 to 7 (9 being the coldest)....
Check to see if the fan in the freezer is running, without it you get no cooling in refrigerator. If that's ok check for ice buildup on back freezer wall if so you have a defrost problem
Jun 22, 2011 | Kenmore Top Freezer Refrigerator
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrig will not syay cold Only 6 months old
Good day,
Not your problem. The machine carries a full one year warranty on all parts.
Call Sears for a warranty service call.
Feb 05, 2010 | Kenmore Refrigerators
MY FREEZER WORKS BUT NOT MY FRIDGE WHAT CAN i DO?
Good day,
There was a time when most Kenmore refrigerators were produced by whirlpool, but no more. A model number would help. So the answers are generic.
1. The defrost system failed. Tell-tail signs included frost building up on rear panel of freezer comportment. The system is made up of three parts, and is the most common cause for your problem.
Look here for an idea on how the system functions..
http://www.appliance411.com/faq/howdefrostworks.shtml
2. The fan motor in the freezer compartment failed, not discharging cold air to the fridge compartment. You should be able to hear the fan running, when you open the freezer door.
3. Lights not going out when the fresh food compartment door is closed.
4. On some versions, if the freezer control is set too old, it will deny the fresh food compartment enough air to cool.
5. On other styles the control for the fresh food compartment is pneumatic (opens and closes to allow more or less air in as needed). This control can fail shut, not allowing any cold air to enter the fresh food compartment.
Nov 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Kenmore refrig. 13 yrs old. frost in back of freezer, compressor not kicking on. some cold air, but won't keep food cold enough model: 9552710
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Refrigerators
Refrigerators Logo
110 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
