Question about KitchenAid KSRD25FK Side by Side Refrigerator
Water dripping under our kitchen aid supra refrigerator
Does it have an icemaker? Was the water line plastic tubing or copper? If plastic, it could have been dried out and cracked by the heat from the motor.
Posted on Feb 13, 2012
  • 1314 Answers
SOURCE: kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Posted on Jul 05, 2008
SOURCE: Kitchen Aid Superba refrigerator
the black panel that runds down the side of the refrigerator between the freezer and food storage area is very hot. also the small light in the freeezer is blinking even though i have it turned off
Posted on Aug 07, 2008
  • 115 Answers
SOURCE: change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
Posted on Jan 05, 2009
jan mczeal
  • 632 Answers
SOURCE: water from the kitchen tap is good tasting, water
The water has been in the tank for too long. Draw and discard a least 7 glasses of water to freshen the supply. Draw another 7 glasses of water or more to completely rinse out tank. Repeat the process if necessary.
Posted on Oct 26, 2009
Kitchen aid kssc42fts20 dripping water under door ice built up inside bottom of door (defrost time issue?)
If i were you I might need a new fan because some of my pat fridges had the same issue and it turned out that it was the fan not working well
Jul 12, 2017 | Refrigerators
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
Leak in the water dispenser
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jun 30, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water despenser in door drips water
Hi!!! you seem to have a problem that everybody in the world has..Its normal at there is nothing you can do about it unless you install an antisyphon in the water line kitchen aid has one.Good luck..
Jan 05, 2009 | Frigidaire FRS23H5AS Side by Side...
KitchenAid KSRD25FK Side by Side Refrigerator Logo
91 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
