Question about Apple Audio Players & Recorders
A 5146 manual
On how to delete music and to put new songs on
ctf1800
  • 4402 Answers
SOURCE: digital mp3 player
need make and model
Posted on Feb 12, 2008
  • 19 Answers
SOURCE: where do i get a manual
The manual is here.
http://www.ccrane.com/instruction-manuals/sandisk-sansa-e250-mp3-player-sdmx4-2048.pdf
Posted on Jul 25, 2008
SOURCE: I can't delete songs from my Mp3.
I had the same problem.
On the MP3, go setting and then to USB.
There are two options: Auto Detect or MSC. One will be checked showing the current connection type. Select the other one and connect the Sansa to your computer.
For some reason, the Sansa doesn't recognize files loaded in MSC if you're connected in Auto mode and vis versa.
In MSC mode, it will show up as a devise with a drive letter. In Auto mode, there's no drive letter; it shows up as a removable devise.
Also note, you can only add Playlists in the Auto mode. MSC mode does not recognize Playlists or if it does, I haven't figured out how to do it
Posted on Dec 09, 2008
SOURCE: i deleted the music folder and nt able to play the songs in mp3
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Posted on Mar 16, 2009
Fame_Guru
  • 483 Answers
SOURCE: I cannot delete songs from mp3 player
Try Downloading it from here ;
http://portablemedia.manualsonline.com/manuals/mfg/philips/philips_mp3_player_product_list_9.html
Let me know if this helps :).
Posted on Mar 18, 2009
How do i delete all songs on ipod shuffle and then reload? I want to empty it and start over as if new
How to Delete All Music from iPhone / iPad / iPod
  1. Open the "Settings" app and tap on "General"
  2. Select "Usage" and then choose "Manage Storage"
  3. Tap on "Music" to select the song library on the iOS device.
  4. Swipe to the left over "All Songs" then tap on the red "Delete" button when it becomes visible.
Remove All Music from iPhone, iPod touch, iPad - OS X Daily
osxdaily.com/2012/02/18/remove-all-music-from-iphone-ipod-touch-ipad/
delete all songs on ipod Google Search
Feb 08, 2017 | Apple iPod Audio Players & Recorders
I bought an ipod 2gig nano with 117 songs downloaded. I like maybe 30. how can I delete the other songs?
Generally speaking, you'll clean up your iPod with iTunes to erase unwanted songs and add new songs. You have two ways to delete music from iPod with iTunes, and they can be helpful when you want to get rid of the unwanted songs. iTunes provides automatic and manual methods to help you manage the songs in your device. When you are using the automatic way to manage iPod music, every time you connect iPod to computer with USB cable, your iPod will sync with iTunes Music library. If you have your iTunes Music library organized, you can delete unwanted music from iPod with this easy method. If you want to manually edit your iPod music, you can check Prevent iPods, iPhones and iPads from syncing automatically in iTunes by clicking Edit > Preferences > Devices. Then you can manually sync the songs and playlists to your iPod with iTunes.
bought-ipod-2gig-nano-117-songs-oxaxc0rwhkhzilrwacqreyis-5-0.jpg bought-ipod-2gig-nano-117-songs-oxaxc0rwhkhzilrwacqreyis-5-5.jpg How to Delete Music from iPod
Sep 07, 2016 | Apple iPod nano
How do I delete songs from my ipod?
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
Apr 10, 2013 | Apple Audio Players & Recorders
How do i delete songs from an Iphone 3gs
1.Go to Settings
2. Go to General
3. Go to Usage
4. Wait for Storage to load
5. Go to Music and swipe
6. Delete will pop up
7. Press Delete
This will delete ALL songs, but will not remove the music app.
There you go.
How to Delete Songs from iPhone
iPhone Data Eraser Clean up Data Safeguard for Ultimate Privacy...
Oct 25, 2010 | Apple iPhone 3G Black Smartphone
My mp4 deletes songs when I try to put new ones on it why?
hi,
if you sync you iPod , all the music in the iPod will be deleted.
what you need to do is to click on your iPod icon when you connect it to the computer and then check "Manually manage music".
then you need to create a playlist, put all the songs you want to add in your iPod, then under the iPod click on Music, and you will see "Autofill from:" below the window.
select the playlist yu created and click on autofill.
thus the songs will be added without deleting the ones which were already on the iPod.
Oct 10, 2010 | HiHiSoft Free MP4 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Deleteing music
Put songs your daughter does want on the MixMax, and then click "shuffle". It should load the new songs while deleting the old ones. Good luck!
Aug 06, 2008 | Disney Mix Max Digital Media Player
Deleted songs
Look in the music folder (top left of the main itunes page). You should see all of your songs there. If they are there, then plug in your ipod, click on the name of your ipod (left hand ide of the screen) and check the box on the main screen that says (manually manage music). Then go back to the main music folder again, and select all of the songs, (you can do this by clicking on the first ong in the list, hold down the shift key and then click on the last song in the list), then drag and drop all of the songs onto your ipod in the list at the left.
Jan 29, 2008 | Apple iPod nano
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
190 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
