Question about Watches
How to remove a link from the invicta 6674 watch
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Job done!
Posted on Apr 02, 2009
  • 61 Answers
SOURCE: how to remove watchband links from an Invicta
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Posted on Oct 21, 2009
SOURCE: Adjusting band on Invicta 4901
I was having the same problem with mine. Even though the band has arrows, those really are screws in the band. Two really small screwdrivers and you can take out the unneeded links. They are in there really tight, so expect some resistance until they pop loose, after that its easy.
Posted on Dec 03, 2009
Testimonial: "Thanks, I'll try that. I tried 2 screwdriver before but I was afraid of breaking something. This gives me the confidence to keep going."
How to remove links from Invicta 0132 wildflower
Normally on this type of Invicta you would use a slim punch to push out the little pins at each end of the link section you want to remove, then reattach the band using one of the removed pins.
In some cases one end of a pin will be slightly wider than the other so that the pin is meant to be removed in one particular direction. If you can't tell any difference, the pin will probably come out either way. You may use a small hammer to tap the pin back in if needed but don't scratch your band.
Feb 07, 2015 | Invicta Watches
How to remove links from invicta sea spider polyurethane bracelet
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Nov 24, 2011 | Invicta Sea Spider Chronograph...
How do you remove the back of an invicta model 3459
here's is a video on how to open the caseback of your watch. i hope this will help you. just click the link below.
http://www.youtube.com/watch?v=bYTlqox3aA8&feature=player_detailpage
Jul 30, 2011 | Invicta Vintage Collection Chronograph...
How to remove links from invicta grand diver quartz chronograph teak j179195
Thank you for contacting FixYa
You can find how to do most watch bands at this link:
http://www.webwatches.co.uk/how_to.htm
Best regards.
Jewel
Sep 02, 2010 | Invicta Watches
I have an invicta reserve watch how do i remove the pins to adjust the band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please
Mar 14, 2010 | Invicta Power Reserve 1948 - 9979 Wrist...
How to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Jun 17, 2008 | Invicta Watches
Watches Logo
126 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
