Question about Ovens
Our display says L50 latch/door. What does this mean?
F5eo code and door lactch is out?
Error code F5-E0 means a Door Latch failure and is displayed due to malfunction of door latch-switch assembly.
To start, I suggest check the door latch switch, if this is good, then recommended replacement of door latch-switch mechanism.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose.
Oct 22, 2011 | KitchenAid KEBC107 Electric Single Oven
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
J SP420 NIBB GE oven Display reads FC locked door and oven will not work but stovetop works.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board.
You may need to get an appliance repair person out.
Mar 18, 2011 | GE Ovens
I have A F9 code on the display on my jenn-air stove what does this mean?
This indicates a problem in the door latch circuit. First check that the latch is fully opened. If it is acess the door latch motor and check for a shorted motor, to do this get an ohmeter and put one lead on the red or black wire and the other on the motor housing you should get no reading if you do replace the motor. If the motor checks out good replace the ERC electronic range control, before doing this unplug for 5 minutes and see if it will reset. To replace the ERC this link should help http://appliancehelponline.com/ovenerc.html
Jul 20, 2010 | Ovens
How to open door on kitchenaid oven after cleaning cycle is over the there is no power?
do you mean no power to the unit or no display?
if no power, then reset your house breaker and then push the cancel button. it should unlock.
if you have a good breaker, then the unit most likely has a failed thermal fuse. this happens alot on these.
there is a thermal fuse on the back of the unit that will cause the unit to not heat, and another thermal link in the wiring harness at the control board. if this one is bad, then you wont get any display.
you can get the door open by taking a bent wire coat hanger and locate the latch between the doors and pull it sideways to free the latch. then you can remove the control panel and get to the thermal link.
Jan 10, 2010 | Ovens
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Oven display problem
F5-E1 is a fault code denoting a failed door lock/latch mechanism. Before having it replaced, go outside to you main breaker box and turn the power off to it for a couple of minutes... try to reset the controller. If the fault code appears again, the door lock/latch mechanism needs to be replaced.
Jul 26, 2007 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
