Question about Frigidaire Dryers
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
    President:
  • 2,468 Answers
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Posted on Feb 13, 2012
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Kenmore electric dryer will start for few seconds then shuts off
timer need to be changed
Posted on Feb 18, 2009
localwonder
  • 6784 Answers
SOURCE: PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Posted on Jun 03, 2009
milten1
  • 1304 Answers
SOURCE: Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Posted on Oct 19, 2009
heatman101
  • 43501 Answers
SOURCE: My Gallery series dryer is turning off after about
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Posted on Mar 07, 2011
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
What do error PF mean?
It seems like problem is in main control board or problem could be related with other components .As PF stand for power failure in dryer and it could caused by many factors
Mar 04, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Have kenmore 61951 dryer PF comes on go thru the steps it turns on and then shuts off what could be the problem
PF is a power failure error meaning electricity has been interrupted to the machine. Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code. Try resetting the appliance by disconnecting it from the outlet or switching off the circuit breaker for 20-30 minutes, then restore the power. If the reset doesn't work I suspect the control board has failed.
Jan 12, 2011 | Kenmore Dryers
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Has code PF and will not start Beeps constantly
PF means a power failure has occurred.
Press and hold the cancel button for several seconds to clear the error. Then press start. If the problem still exist you can unplug the unit wait several minutes an plug it back in. If the error still appears the control board maybe at fault.
Nov 12, 2009 | Kenmore Elite HE4 Electric Dryer
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
My kenmmore dryer screen is reading pf and i want to nkow how to solve the issue?
pf indicates a Power Failure, press start to resume cycle (if in operation at time of fault) or turn off for 5 seconds and turn back on, error code should be cleared.
please take the time to rate this solution
Jan 29, 2009 | Kenmore 74602 Gas Dryer
Dryers Logo
69 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
