Question about Vacuums
Kitchen exhaust fan no suction, though motor turns and fan blows
Tradewinds VCH-7 and ventilator VR1000 on the roof, motor and fan blows but no suction I have a probably 30 year old Tradewinds kitchen range top fan, VCH-6 and roof ventilator VR1000. The motor turns and fan blows pretty strong, but there is no suction at the range top. No suction at all. I wonder if it's due to the duct is blocked somewhere. I used a mirror to see from the kitchen range top to as far as I could see. I was hoping to find some damper with shutter. So far I have found any mechanism that blocks the air flow. I'll appreciate if someone could provide suggestions what I should look for. Thank you, James
5 Suggested Answers
SOURCE: Dyson Dc-17 Animal Doesn't ****
I had the same problem and today I finally called Dyson. They were very helpful. I disconnected the hose from the handle using the red release button. If you hold the handle up to the light and can't see light on the other side, there is a blockage. A wire coat hanger worked great to dislodge our blockage and it's working perfectly again!
Posted on Apr 13, 2008
SOURCE: dyson blowing top of cyclone air release valve.
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
Posted on Jul 11, 2008
  • 6 Answers
SOURCE: dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
Posted on Mar 03, 2009
  • 694 Answers
SOURCE: How do I gain access
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Posted on Sep 12, 2010
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
How do i change from vacuum to blower?
In order to change from suction to blowing, insert the hose into the
exhaust port of the vacuum cleaner.
The vacuum cleaner should have two ports, one which is for suction,
the other is an exhaust port. The exhaust port can be used for blowing
when the hose is inserted into it.
After inserting the hose into the exhaust port just turn on the switch.
Jan 17, 2011 | Black & Decker UV200 Wet/Dry Vacuum
I have a Dirt Devil Jaguar bagless vacuum. It used to work great. Now, it is blowing a huge amount of dust out of the front of the machine as I try to vacuum the carpet. can this be remedied?
This generally happens if the hose system is clogged. No suction so the power head brush just kicks out the dirt and debris you're trying to pick up, and loose stuff that is currently in the hose system. If it has been doing this for quite a while, or has been used with blockage, the motor has to work harder and will eventually burn out, if there is no overheat shut of switch in the cleaner.
Check all parts of the hose system, from the power head to the tank. Clear all clogs. That should take care of the problem.
Another possibility is that the fan blades are broken or worn down. This would result in no suction even though the motor is running.
Dec 09, 2010 | Dirt Devil Vacuums
I have cleaned out the vac and changed the filter but I can hardly **** up leave on the garage floo.
Try this:
Detach hose, turn on vacuum, hold hand in front of intake to check airflow/suction. If it seems good, you either have a clog in the hose, are bad leakage.
If it's a clog, try placing end of hose in the exhaust port, turn on machine, and blow clog free. You may need to place other end into intake. This should clear it.
If hose is cracked, punctured, or smashed/collapsed, replacement will be necessary.
If there's not much suction at the intake, it may be time to replace your vacuum, or at least the motor.
Nov 13, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
No suction but good exhaust flow
This sounds like you have a loose pipe connection somewhere in your system. Physically check all connections. If you can't find anything suspicious, call a vac repair man that specialies in central vac repair. Joe
Aug 10, 2009 | Electrolux Centralux Vacuum
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
I don't have any suction
finish cleaning, through the whole air path
usually, by the time that a large clog has built up in the narrow neck behind the brushes,
that is easy to find when the cover plate is removed,
some has also got into the fan impeller,
not so easy to see
and restricts suction
the fan housing is held on the front of the fan & motor with clips, it disassembles easily and the lint and such can be flicked out of the impeller
then the exhaust of the motor to the bag can be likewise cleaned
Nov 05, 2008 | Eureka WhirlWind 4381 Upright Vacuum
No suction on my red roomba
Make sure you have a filter installed, then change or clean it. Without a filter, the fan will get clogged.
If that doesn't help, clean the fan and the exhaust port, and verify that the fan is working.
If the fan is working and the filter is clean, then your appearent lack of suction is probably due to the fact that your brushes are not turning, and therefore not collecting debris. That's a whole different problem, one I also have, but haven't solved yet (though there are suggestions on this site).
May 01, 2008 | Roomba Robotic Floor Bagless Vacuum
Central vac toast?
Most of these motors, the fan cover is just pressed on, but getting off isn't easy and you don't want to bent it up. Maybe using a flatblade try to knock it off from the edge of it may loosen it enough to pull it off.
Mar 18, 2008 | Vacuums
Vacuums Logo
98 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
