Question about Gestetner DSm730 Black and White Copier
Im machine show me an SC544 error what do i do guys, im using Gestetner DSM 730?
goodgold
  • 389 Answers
SOURCE: reset photoconductor unit gestetner dsm415
Zeroizing the counter Fotocondactor. The Sign - twinkle all lamps, in readiness not vyhodit.
1 To Press "copy" and include feeding with pressed кнопой. All indicators, except "Ready", light.
2 Release "Copy", press her(it) once again and keep until it is ed indicators "Toner" and "Paper" 10 sec
3 Release button. Switch off feeding, wait 15-20 sec, include once again
Posted on Sep 23, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: how do you install an ethernet card on a gestetner DSM645 copier/
Are you trying to install an ethernet or "NIC" card in order to turn the machine into a printer? If so then you need more than a nic card. You would also need a ROM chip, Print controller, Hard Disk Drive and the buttons for the control panel.
If you are just replacing a NIC and expanding the memory then that is possible but the instructions to do so would be more than could be typed up here.
Posted on Jan 16, 2010
  • 903 Answers
SOURCE: Faxing with Gestetner DSm 635 sp Copier
There is a fax module that you can purchase to be able to fax from the copier. If it is already installed, you will see two phone jacks on the rear side of the machine. One will be labeled "Line" and one will be labeled "Tel" -- if you plug a phone cord from the jack in the wall to the jack labeled "Line," your copier is all ready to fax.
On the operation panel, there should be a button on the left labeled "Fax" under the buttons labeled "Copier" and "Document Server" -- press that button to get to the fax screen.
Hope that helps!
Posted on Jul 18, 2010
  • 183 Answers
SOURCE: how to install gestetner DSM
open finsher and yo will find like knob pull it yo will find wth our languge lokcha this expression refer to stapler
Posted on Jan 06, 2011
santosj27
  • 263 Answers
SOURCE: my gestetner copier dsm 616 use to show sc 322
That code refers to a Laser problem.
It could be toner dirty and only need to vacuum it. But you have to know how to get in the Laser unit.
If you do not have that knowledge i advise you to call your technical support.
Posted on Jun 29, 2011
I have Gestetner DSm 615 but it does not show where to insert Ethernet card
Hi ya,
k, not sure if you have all drivers n stuff so maybe you'll get what you need from here, click or copy link, hope this helps, n g'luck, paul. http://support.ricoh.com/bb/html/dr_ut_e/nrg/model/x2015_18/x2015_18en.htm
Jun 17, 2016 | Gestetner Dsm 615
Where is used toner bootle dsm 635
it has not waster toner bottle on the machine, the waster toner is being recycled in the photo-conductor unit (PCU) so if the machine show replace the waster toner bottle just clean the PCU of the machine on the drum upper area
Sep 21, 2015 | Gestetner 3532 4532 Dsm635 Dsm645 Toner 4...
Savin 8045 sc544
error 544 is associated with the fuser, call aechnician to change the thermisters and thermofuse of the fuser and the problem is solved
goodluck
Feb 05, 2014 | Gestetner Office Equipment & Supplies
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
My gestetner copier dsm 616 use to show sc 322 code
Jun 29, 2011 | Gestetner - DSM-616 COPIER Copier
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
Error sc 326 in dsm 635
First of all check that the laser **** glass is still there, I've seen a couple of machines where the **** glass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
May 04, 2010 | Gestetner DSm635 Copier
Service code sc544
It is a fuser overheat error....really has to be checked by a technician...
note that any Ricoh tech can also do it as it is a Ricoh machine
Nov 06, 2009 | Gestetner DSc224 Copier
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Gestetner DSm730 Black and White Copier Logo
78 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
