Question about Pool & Spa
Pelpro pellet stove blower motor won't shut off
protek480
  • 1714 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Posted on Jul 01, 2009
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
SOURCE: Pelpro pellet stove will not start. Press the start
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Posted on Nov 15, 2010
  • 102 Answers
SOURCE: I may need a blower moter for my Envirofire pellet
If you cant find it through the manufacturer try matching the motor with grainger.com they have awesome electric motor tech support that can match it up. Make sure you get all the info off the motor before you call them. If you cant get anywhere with them you can email me the motor specs and I can further assist you.
Posted on Dec 14, 2010
  • 223 Answers
SOURCE: I have a Quadra fire 1200 pellet stove insert. The
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Posted on Jan 11, 2011
I cleaned my Harman Pellet stove today and when I went to start it the feed motor won't start. The blower runs for about 15 sec then shuts down
Test the feed motor with a jumper and wire power to it directly, if that fails to make it run you have a defective motor.
Dec 27, 2016 | Pool & Spa
Can I run a pellet stove off a generator its a 3500 Watt generator I bought at tractor farm supply Just need to know Yes or no I got a harman invincible insert pellet stove
If you are just running the blowers and what not, then yes you can. Blower motors do not take more than between 200 and 500 watts or so, so you should be okay running the blowers.
Jan 06, 2014 | Electrical Supplies
Brand new Propel Keeps shutting off
Take it back and replace if not working properly. Why go crazy. U paid with good money - you are entitled to a good working product.
Aug 24, 2017 | Pool & Spa
Pelpro pellet stove will not start. Press the start button, igniter button lights up but nothing happens.
Oct 11, 2009 | Coleman Dryers
Pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Pool & Spa Logo
484 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
