Question about Nokia N72 Cellular Phone
Crashing in the middle of sending a picture message
I was sending a picture message to my friend, but half way through the screen reboot itself flashing back and forth between the nokia start up screen. Then it went back to normal, but now the "sending message" notification in the corner won't go away. It still works properly but the thing is still there. How do I get it to go away?
SOURCE: Nokia 5300 Wont Send Text Messages
i had the same problem. first try turning the phone off then back on and if it doesnt work after that then go into menu>optus>SIM Backup and turn it on
worked for me
Posted on Apr 28, 2008
  • 726 Answers
SOURCE: Nokia 6120 question
could mean message bank.
or delete all your messges inbox, outbox, sent ,drafts then turn phone and on again ,if happenes still let me no ill find out more information
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: I have two new nokia phones, the 6220 and the
Please check for unread messages in the inbox or unsent messages in the outbox
Posted on Aug 04, 2009
  • 53 Answers
SOURCE: Nokia 6720 sms notification not working
reset it n try
1. phone setting
2. reset factory default
3.code is 12345
4. after restart u choose profile n set the sms ringtone
Posted on Jun 02, 2010
lexzy80
  • 943 Answers
SOURCE: My Nokia E52 won't charge.
This problem can be traced to only a few causes. Listed below are the causes and possible solutions to this problem.
1. It is most likely that your battery may not be having proper contact with the terminal that does the main work for charging it. The three terminals that can be seen perform different tasks and as such, when that which is responsible for drawing power from the battery to operate the phone is in good contact, the phone might work normally but refuse to charge when that which is responsible for charging the battery is not properly in place. The easiest way to solve this problem is to turn off your phone and remove the battery. Try to clean the battery and all of the phone's terminals without using any liquid and then re-insert the battery.
2. Your phone may be having a faulty charging port and as a result cannot perform the complete task of charging the battery. In this case, the only thing that can be done is to try to dust the charging port and try to charge again. If this actually happens to be the exact problem, you might have to take the phone to a repairer so as to open up the phone and do a proper scan through on the phone.
3. lastly and most unlikely, the battery may have been damaged and needs replacement. This also depends on how long the battery has been in use. If it has been in use for more than 3 years, it is advised you replace the battery. Also, you can try connecting the phone to another power source to see if that helps too.
Hope this solution was helpful?
Posted on May 24, 2011
My text messaging is receiving income but not sending them and then my LG phone will randomly shut down and reboot itself what is going on .....
Hope your message centre number is wrong. Please compare it from your friends or family to correct your message centre number your service Like Vodafone, Airtel, !dea etc. And see whether it's working or not?
thanks for using FixYa All the Best!
Aug 09, 2011 | LG Cell Phones
My dvd/vcr is show double almost like a split screen. There is a bar in the middle of the screen and the screen itself is slpit into two parts. When i put up the menu screen for it i can see half of one...
on your remote you need to hi the pip button. thats picture in picture. it allows the screen to be split so you can watch two things at once, though most equpiment doesnt support this function yet so its useless.
Hope this helps. Please take a moment to rate:]
May 07, 2011 | Televison & Video
My daughter just dropped her acer aspire netbook. Only half of the screen is visible the other half is white and black with a line down the middle
Dropping the netbook will have probably broken the LCD screen.
There is no other way to repair the problem without replacing the screen itself. You can however use a external monitor and use the keyboard to toggle between the two screens.
I know this is probably not what you wanted to hear but unfortunately LCD screens are fragile so a good knock can crack them causing only one half or the part or the screen which is not broken to show. The backlight itself sounds like its working as there is still light showing behind the cracks.
Regards.
Mar 14, 2010 | Acer Aspire One PC Notebook
My Blackberry curve 8310 constantly reboots when I'm in the middle of a text, a phone call, or when it's just sitting on my desk. It happens several times a day. It seems to happen less often if I...
This issue only occurs when trying to send a SMS text message from within the call details screen of a call in the call log.
To avoid this issue, complete the following steps to send a SMS text message from the call log screen:
  1. Open the Phone application.
  2. Open the Call Log by clicking the middle button in the toolbar.
  3. Touch the call log/contact in the list without clicking the screen.
  4. Display the menu, then select SMS Text (Name/Number).
  5. If required, rotate the BlackBerry smartphone to switch to landscape mode.
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
Can't figure out how to save pictures sent via text messages
On the view, you have to touch the picture itself in the message and it will give you the option to save it.
Mar 23, 2009 | LG Vu CU920 Cellular Phone
In win set up
hi im josh in cebu phils. friend try this stuff to help you solve the problem.
This is a new error message in Windows XP that is displayed after you've had a program crash. (In Windows XP—in most cases—a program crash doesn't crash the entire operating system.) The message goes on to tell you that a log of this error has been created, and then prompts you to "please tell Microsoft about this problem." If you click the Send Error Report button, your computer will connect to the Internet and send the aforementioned error report to Microsoft. You also have the option to not send the report.
What happens when you click the Send Error Report button? Well, you can see for yourself by clicking the "To see what data this error report contains, click here" link. Windows will now display a totally incomprehensible collection of technical information that doesn't tell you diddly squat.
The big concern, of course, is how much of this information is technical and how much is personal; most users don't want to send Microsoft any more personal data than they absolutely have to. Microsoft says that they don't intentionally collect your name, address, email address, or any other personal information—however, the error report itself might include data files that contain this type of information.
So, should you send the error report? I'd recommend not, as you don't directly benefit from it; Microsoft uses this information for future bug fixes, not to help you with your specific problem. Just click the Don't Send button and continue with whatever you were doing before the message appeared.
By the way, if you get this message every time you turn on your PC, you need to update your version of Windows XP with Service Pack 1. This is a bug in the original Windows XP code that affects a small number of systems, and was fixed by Microsoft in SP1.
Unmountable boot volume This message is generated when certain Windows XP files become garbled, making your hard disk inaccessible. The solution is to use XP's new Recovery Console utility to repair the installation. Follow these steps:
  1. Reboot your computer using the Windows installation CD.
  2. When you see the Welcome to Setup screen, press the R key on your keyboard to start the Recovery Console.
  3. You're now presented with a command prompt. Enter chkdsk and press Enter.
  4. Enter exit and press Enter to quit the Recovery Console and restart your computer.
If this doesn't fix the problem, restart the Recovery Console and run the chkdsk /r command.
Windows protection error This error typically occurs when your computer attempts to load or unload a problematic virtual device driver (VXD). In most cases, the problematic driver is mentioned in the error message; in other cases, however, you'll have no clue as to what is causing the problem.
If you can track down the driver causing the problem, you can usually fix things by reinstalling or updating the driver, repairing any damaged Registry entries, or eliminating any driver conflicts.
good luck friend.
Mar 04, 2009 | ASUS P4SGX-MX Motherboard
I cant receive picture messages
The problem is that supposedly before you can receive picture messages, you have to send one first. Tell a friend that you are going to test it out on them and send them a picture message. It will take a while for it to go through
Then all the texts that you receive before with the "download' button in them in the place of a picture automatically turn into pictures.
Unfortunately as it stands there is no functionality for saving your MMS pictures directly onto your phone, the only way it can be done is you have to forward the message to your Gmail account, which will then arrive on your phone and from there you should be able to open the email and download the picture. To do so follow these steps
From the Home screen, touch the Applications button.
Touch Messaging.
Touch the message that contains the picture or video.
Press and hold in an empty space in the message.
Touch Forward.
Type a space or other character in the forwarded message (in subject or body of message)
At To, type the e-mail address.
Press the Menu key and touch Send.
Once received in the email this can be saved but the problem is when saved it may save it without a file extension therefore making it unviewable later
This should help and do let me know
Mar 04, 2009 | HTC G1
Problem with texts - Samsung U900 Soul
it is something that the network and manufactured installed on phone which is annoying the best way is to send texts half and half so they arrive to friends
Dec 08, 2008 | Samsung U900 Soul Cellular Phone
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
