Question about Acer Aspire Computers & Internet
My Acer Aspire 5517 shows black screen only
Powers up an then black screen
  • 10 Answers
SOURCE: Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Posted on Jun 15, 2009
  • 107 Answers
SOURCE: power lite is on, screen is black.
This seems to be a common issue with this model. If it is still under warranty send it back to acer. If not you can try this fix at http://eric.chromick.com/aa1/aspire-one-black-screen-of-death/
Will not hurt it anymore than it is.
Posted on Jul 04, 2009
ailia
  • 175 Answers
SOURCE: acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Posted on Jul 08, 2009
  • 13433 Answers
SOURCE: acer aspire 9300 screen doesn't show
You got two year warranty on it? My acers have always had only 1 year warranty.
The laptop is most likely unable to start up. In most cases its a hardware issue, should take the laptop to a local professional for a check or if your in warranty contact acer.
Possible reasons could be bad memory, overheating, failed mainboard, failed video adapter, loose contact between display and mainboard.
You can try reseating the memory in the bottom of the laptop, it will be covered with 2 screws.
Remove them, and take out the ram from the computer, make sure they are clean, do not use water, or clean them, you can use the eraser end of a pencil to clean the contacts on the memory modules.
Place them back in and make sure they are in the right away, only handle them from the sides.
If the problem still remains, unplug and remove battery again, (might aswell keep the battery removed untill the issue is solved.)
Remove both ram modules from the laptop.
Start up the laptop with no ram at all, it may beep or complain, or it may do noting, unplug after 1 minute.
Plug in the other memory card, plug the machine to power, try starting up, if it works, turn it off and place in the other aswell, turn on and see if the machine works, if it does, problem solved. If it does not work.
Remove both ram modules, try the other memory on both slots and try starting up each time, remember to unplug power every time.
If the problem remains then do the same with the other memory module try it on both slots.
Next thing you could check at home is the cables between the display and the mainboard, you can also check the display in a dark room or under a light and see if there is picture on the display but no backlight, in that case the issue could be the cables between the mainboard and the inventer or the inventerboard or the backlight itself.
This will require repair in any case take it to a local professional.
Posted on Sep 11, 2009
SOURCE: acer aspire 5517 touchpad doesn't work. We have
On my Acer Aspire 5534, up above the keys there are 2 buttons that are side by side. one is to turn the wireless off and on and the other one is to turn the mouse pad off and on.
Posted on Dec 21, 2009
Factory reset acer aspire 5517
greetings!
here is a bing related search that should walk you through the proper process of facorty resetiings you acer aspire 5517
and remember just because your model # is specific does not mean the same factory reset technique is not amongst all the other models as well when troubleshooting.
if you fail in your attempt i suggest you contact acer technical sipport so then can walk you though the process.
here is also a link to their support page.
factory reset acer aspire 5517 Bing video Service Support Acer Official Site
Dec 29, 2015 | Acer Aspire 5517 Laptop
Why is my aspire 5517 screen black
Might have a faulty inverter on your screen.
Jul 10, 2014 | Acer Aspire 5517-5671 15.6" Wifi 1.6ghz...
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
Acer aspire 5517 wont power up
Sounds like your power cord/charger got fried. Either that or the motherboard. Bring it to a pc shop and have them test the power cord/charger.
Jun 29, 2012 | Acer Aspire 5517 Laptop
I have an Acer Aspire 5517, the power comes on but the screen is black, what can I do to fix this?
open the case and try to remove RAM(memory)if you have just 1,put it to other slot for a few minutes the turn on pc
Feb 13, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Does my acer aspire 5517 have a built in microphone for the webcam?
Sorry your laptop doesnt have a microphone only a webcam here are the specs for that laptop http://www.geekwithlaptop.com/acer-aspire-5517-notebook
Jun 04, 2010 | Acer Computers & Internet
Aspire 5500 5570-2609 Laptop Computer (AS55702609RTL) PC Notebook: i have an acer 5517 and there is no d!@# mic. i a...
ACER Aspire 5517 Black Single Side Earphone w/Microphone
Features:
* Ear-hook Earphone Microphone securely in place.
* Fashion design, enjoy sound experience,...
Ref#: 39919
I got this for under $5.00 from:
http://www.cellularfactory.com/laptop/ACER/3/423353/
May 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
1,878 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
