Question about Mitsubishi SD105U DLP Projector
Projector sd105u When I turn it on, the status and power turn green but status starts to flash and then power to nothing. Status still flashes for a bit then goes blank and then power turns to red.
SOURCE: Lamp turns off
The solution is a weird one. I had the same problem with my Sony Cienza VPL-HS1. Run for about 5 minutes and then the lamp would go out. The warning would show that Lamp/Cover was an issue. I assumed the lamp had reached its lifespan.
Wrong.
All it was, was the filter sitting in the filter box has a small trigger switch that turns off the lamp as a safety when someone inadvertently opens the cover for the filter.
Well, strangely enough, the box and the cover are sized in a way to expand when they heat up. (which they do aggressively) When they heat up they expand, and ever so slightly move the filter away from the switch far enough to trigger it to the off position (only about 1/64th of an inch).
Thats why when some of you tip your projector on its side it runs ok (gravity pushing the filter back in place).
The solution is to put a tiny strip of duct tape along the far edge (the edge opposite of the switch) of the filter on its plastic surround. This will snug-up the filter harder against the switch. Even when it tries to shift under expansion and contraction, it will not allow the switch to poke out far enough to turn off.
So, a penny of tape does the job!
JC Dallas Texas
Posted on Dec 22, 2007
SOURCE: Projector turns off after about 30 minutes? What's wrong.
Check to be sure the safety switch at the filter is not being tripped when the case and or the filter surround gets hot and expands. Thats what mine did.
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
joeshea123
  • 65 Answers
SOURCE: The projector suddenly shuts off.
have you check the filter?
Posted on Mar 27, 2009
  • 22 Answers
SOURCE: Hi, My hc1500 Is having a problem. When I turn it
The clicking sound is the high voltage power supply trying to
ignite the gas in the lamp. The lamp is not firing and coming on.
Check the bulb/ lamp life. Possible the lamp has exceeded its
useful life and may need to be replaced.
Posted on Jul 21, 2010
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Nov 19, 2006 | Mitsubishi HC900U Multimedia Projector
Mitsubishi SD105U DLP Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
