Question about Samsung SCX6320F Black and White Copier
Unplugged machine and now it won't turn on
  • Marie DiPietro Feb 12, 2012
    No power at all, It has done this type of thing in the past but eventually turned on several hours later. However, this has been 2 days... Is there a fuse or something that I need to check?
    Master:
  • Samsung Master
  • 551 Answers
Dear
Pl. check the power outlet of socket and power cable.
Thanks.
Posted on Mar 04, 2015
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Even with battery charged, sometimes the machine won't turn on when unplugged
It sounds as though you have a defective battery. You will have to go through Macintosh for assistance.
Apr 27, 2012 | Computers & Internet
Why will my curvy not thread the bobbin or sew?
every one is asking the same question about the machine, if you don't
have a manual I'm putting in a link for a free one
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
if you have the machine plugged into the wall outlet & into the machine
correctly, & it won't sew, you may have to send the machine back & get
a different kind
Apr 21, 2012 | Singer Curvy 8770 Electronic Sewing...
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
Washer water will not turn off . You have to turn water off & let wash & then turn back on to rinse
Hello, Thank You for using FixYa. I will be helping you today.Unplug the machine if when you turn the water on and it fills with unit unplugged you need a new fill valve. If its unplugged and water on and it doesn't run its the timer
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Admiral AW22 Top Load Washer
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Samsung SCX6320F Black and White Copier Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
