Question about Cell Phones
Need to replace faceplate for nokia 5300
Want to know how to remove old face plate and install new one
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Posted on May 21, 2009
I need to know how to remove a DVD drive for a HP lap top.
If your HP Pavilion DV6000 series laptop computer has a bad DVD drive, use the following steps to replace the drive
Purchase a new DVD drive to replace the old HP drive. You can use any slim DVD drive with a 50-pin ATAPI IDE Interface Connector. You will probably want a DVD burner since the original drive was capable of burning DVDs. The drive I used to replace the HP drive is a LG Black IDE Super-multi Slim Notebook DVD Rewriter - OEM version.
Unplug the power cord from your HP laptop. Remove the laptop battery from the back of the computer. This will eliminate the chance of power damage to your computer
Ground yourself by touching a metal object or touch your screwdriver on the ground while touching part of the metal. Unscrew the DVD drive screw circled in the Step 2 photo. Using a small Phillips head screwdriver turn the screw counter-clockwise until it is completely loosened. You may need to flip the computer over to get the screw to fall out. Put the screw in a safe location for later.
Put a small pointed tip object (a paper clip will also work) into the drive release hole on the face of the DVD drive. Use the hole to pull the drive out from the laptop body.
Remove the mounting bracket from the old DVD drive. There are two small Phillips head screws that need to be removed by turning them counterclockwise. Match the bracket up with the holes on the side opposite of the connection port. Using the two screws you just removed, secure the mounting bracket to the new DVD drive by tightening them in the clockwise direction.
Remove the original HP DVD drive face plate from the old drive. It can be removed by working it back and forth to loosen the faceplate. Once it is loose you should be able to pull the faceplate off.
Do the same for the new drive. Once the DVD faceplate is off, match the tabs of the original HP faceplate up and press in until it clicks into place
The new drive is now ready to install into the HP DV6000 series laptop. There is no need to hook up IDE cables and power cables. The new drive can simply be slid into the HP laptop.
Find the screw from Step 3. Make sure the DVD drive is pressed in all the way. Install the small Phillips head screw in the back of the laptop and tighten by turning clockwise.
Jun 19, 2010 | HP Pavilion dv6000z Notebook
I have the same problem that the Grtpumpkin solved.
you have a bad flexible cable. it needs to be replaced. unless you are good at soldering i would not recommend you replace it yourself, as the connector needs to be unsoldered from the old cable and resoldered on the new one.
Aug 24, 2009 | Kenwood KDC-715S
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Complete cover change
Go to my site and download the service manual for the N95. The link will be there for 1 week from today.
Mar 29, 2008 | Nokia N95 Cellular Phone
Crack screen
HI fllow the step plz. open the uper body > open 4 screew > pick the protection plate > u see a jeck of display > plz open with carefully > place a new display > push the jeck tightly > place the protiton plate > put the screew > tight carefully > place the body. keep voteing THANKS.
Mar 22, 2008 | Nokia 5300 Grey Cellular Phone
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
6288 faceplate
It's probably been fitted to another phone tha's why it's loose.
Mar 14, 2008 | Nokia 6288 Cellular Phone
Cell Phones Logo
139 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
