Question about LG VX4600 Cell Phone Over-the-ear Handsfree Headset Headset
Operation My daughter was playing with my phone and now it displays "Car Kit" on the bottom middle of the screen and now I am unable to hear or be hear during a call. I have looked through the menus and I just can't find anything. I have even given to her to play with again hoping that she would undue what she did, but to no avail. Any help would be great.
  • rokmenow Mar 12, 2008
    have the lg vx4600 and cant get it out of manner mode...dont know how i got it in and cant get it out...help..
I had and solved this problem with my VX8000. Changing settings wouldn't fix it at all. I had to clean the contacts at the bottom of the phone. I actually had to open it and clean the contacts inside the phone. Once they were clean it left the car kit mode and worked as usually. I figured this out by doing a Google search on the problem. I just used a very thin, flat jewler's screwdriver to clean any dust out between the wires. Be careful not to bend the wires.
Posted on Nov 09, 2007
You wont believe this but same thing just happend to me with car-Kit thingie but try blowing compressed air on it for a couple mins and it should resolve your problem
Posted on Oct 09, 2007
    Problem Solver:
  • 15 Answers
As odd as it sounds I found help for this on some other sites/blogs/forums. It may be associated with 1 of 2 things. I solved my problem by doing both. First, it may be the phone got wet. So go through the usual steps (won't get into details here for sake of time. You can find this info all over the web if you don't know what to do) But, second trick was interesting and had to do with the connection at the bottom of the phone for the charger and a possible bent pin on the right side....try inserting firmly and removing the power adapter several times....even wiggling it araound a bit....especially on the right side...and believe it or not this worked for me.
Posted on Aug 29, 2007
Need to programe hedsat
Posted on Apr 16, 2007
Just clean out the serial connector at the bottom with a brush and alcohol.
Posted on Sep 26, 2006
    Problem Solver:
  • 14 Answers
To edit the settings for the headset, car kit, or another audio accessory, open Enhancement settings > Headset. Scroll to the following setting and press OK to edit. * Default profile - Scroll to the sound profile that you generally wat to use with the headset and press OK. Hope this works for you.
Posted on Aug 11, 2006
Nokia 1661-2 unable to use Insert SIM / Demo
you can contact this store: www.unlocksolution.com
This guyz helps a lot.
Mar 12, 2013 | Cell Phones
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
I am unable to connect to a bluetooth car kit with my samsung omni hd i8910 phone. Have spent hours reviewing settings on my handset and reviewing phone user guide. I have also checked handset is...
there's 2 things you need to do to get these 2 devices to communicate. One is to make the bluetooth kit "findable" (for lack of a better term). and also have your phone search for the searchable device.
I'm not sure what your phone car kit is.... but check the instructions on how to put it into search mode. (I know that with a bluetooth headset, you hold the on button in and the indicator will change to a different color indicating search mode.
once you figure this part of the equation out, then access the phone menu for blue tooth and search for bluetooth findable equipment and it should list your car kit on the phone screen.
After that it is just a matter of entering a typical 0000 id code if needed and it should be paired with your carkit.
hope this helps...
Jan 27, 2010 | Cell Phones
LG5000 cell phone mode
try to turn off computer,remove battery and turn it back on
Oct 10, 2008 | Cell Phones
Getting an error that says car kit on phone
Mine said car kit and I kept reading it was because it got wet, and my phone didn't get wet. I noticed a little corrosion where I plug the phone in starting to form and I rubbed a little off and the car kit on the main screen went away.
Sep 08, 2008 | LG Cell Phones
Car kit
My cellphone is stuck in car kit mode and i cannot hear anyone calling me but i can text people. How do i get this feature off!
Sep 05, 2008 | LG VX8300 Cellular Phone
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Feb 17, 2008 | LG VX8300 Cellular Phone
Car kit on display screen
It's actually something wrong with your phone. The connector on the bottom of the phone may have gotten wet. If you are comfortable taking the phone apart you can clean the connector w/ 99.5% isopropyl alcohol and a soft bristled brush. Good luck.
Sep 05, 2007 | Cell Phones
Says Car Kit on phone but has never had a car kit hooked up to it
A clarification on solution #1: Try pressing the tip of the knife (I used the end of a nail file) onto the lower right hand side of the charger area. That's what got it for me. If that doesn't work, try other parts of the end...
Aug 16, 2007 | LG VX5300 Cellular Phone
Phone screen says "car kit"
MY LG flip just did the same thing. I took it in and they said there was some corrosion in the battery charger area from water. They had to replace my entire phone. I have a 15 month old that plays with it.
Jul 12, 2007 | LG VX6000
LG VX4600 Cell Phone Over-the-ear Handsfree Headset Headset Logo
165 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
