Question about Sony KP-57WS500 57" Rear Projection Television
Replaced convergance chips adjusted red but blue will not adjust in any direction pico fuse is good Sony KP-57WS500
Is there another way to adjust the convergace
  • Sony Master
  • 3,459 Answers
You can try to adjust in service mode but it sounds like you did not do this repair correctly. I would suggest getting instructions from sites such as www.TvRepairKits.com
Posted on May 05, 2012
ctf1800
  • 4402 Answers
SOURCE: service mode for convergence
You enter the service menu by using the remote. Press DISPLAY, 5, VOL+, POWER in rapid succession. Once the screen appears, you should notice green letters and numbers at the top of the screen. Your remote acts as a navigation tool to allow you to select and change values. Keys 1 and 4 change the Item, keys 2 and 5 change the Category, and keys 3 and 6 change the Value. MUTE enters the write function, and ENTER executes it. Power exits the service menu. Keep in mind that while in the convergence mode, the keys have different functions, which we'll get to in due time. The service manual will also have this information.
http://tv.groups.yahoo.com/group/Ws500/
Posted on Feb 22, 2008
  • 4 Answers
SOURCE: kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Posted on Jan 16, 2009
localwonder
  • 6784 Answers
SOURCE: blue convergence is off right will not adjust
Hi. there is a malfunction that has occurred within the convergence chip that is located on the PC board(demod). this is a Hybrid chip that controls the calibrations of the RGB streams. If this chip becomes unstable, it will not allow proper calibrations.
Replacing this failed chip will fix this issue.
The actual sony chip is not available at this time but, there is a compatible chip that will work with your set. i will post a link to the affected part below.
CLICK HERE FOR YOUR REPLACEMENT CHIPS
Posted on May 11, 2009
  • 14 Answers
SOURCE: convergence is off on sony (flash focus doesn't help)
which colors are more out of line? This will tell you what convergence amp to replace.
Posted on Jun 23, 2009
ladywinn
  • 5138 Answers
SOURCE: sony kp-ws500 has very fine red and blue
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Posted on Sep 16, 2010
There are red, blue and green lines going all the way across
it sounds like a convergence problem; in the customer menu there is an option to adjust it with the Sony remote---if either blue or red will not adjust in some direction---you have a bad IC---this set uses two STK-392-560 IC chips for convergence---both would need to be replaced and the set adjusted again. If this has been helpful give me a vote here---if you need more direct assistance--------- etower.766@netzero.net
The convergence IC chips are available on Ebay from Surburban Electronics for less then 14 dollars for the pair.(plus shipping)
Aug 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Double red image, distorted on bottom
Your TV has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Aug 02, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have sony model KP51WS510 with a red and green shadow also the color is off
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 14, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a sony Projection TV KP46WT510 convergence issue. How can I fix it? I see fusy picture with red and bleu double picture. I tried the convergence fix in manual and it shows the issue but could not...
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture is overlapping with a green and red color
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 06, 2009 | Sony KP-57WS500 57" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-53HS30 My picture is curved at the top and bottom and the writing is like a shadow of 3's red green and blue
  • Screen looks 3D
0667c5f.pngSOLUTION
Mar 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony TV rear proj works but color is blue
Problem : Convergence Chip Failure ( common problem )
  • Screen looks 3D
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
