Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson cx5500 it says parts inside your printer are at the end of their service life in the status monitor i have the same problem.. ibadly need a resetter
  • GTSmelik Oct 27, 2008
    My CX3200 just up and quit with an error saying that something has come to the end of its service life. It doesn't make much sense since everything else was proper, i.e. power is on, everything boots up properly, ink levels are good, etc. What now ?????
  • AlmostBob
    AlmostBob May 11, 2010
    so to fix 'something' we have to know what 'something' is
    Scholar:
  • 89 Answers
See if this works for you:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers. (http://www.ssclg.com/epsone.shtml)
  12. Select your printer and model number, then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done!
Additional troubleshooting…
If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again.
If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Posted on Nov 02, 2008
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
It doesnt work anymore
End life mean ink waste pad full. Printer stop to print because for preventing waste ink flow to other part. It must to reset waste ink counter using resetter software. And replacing/washing pad, or just extend outlet pipe form haed cleaning mechanic to outside. What type of your epson printer, I have some resetter for epson.
Mar 18, 2010 | Office Equipment & Supplies
Have changed inks which were low and now have left and centre red lights flashing and printer will not operate.
Check for epson status monitor : General error or reach end life service ? Flashing alternately mean printer need to reset waste ink counter.
Mar 15, 2010 | Epson Stylus photo C87 InkJet Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
The status of my printer (epson stylus c45)is idle. There's this yellow exclamation point before the message-Service Required then...inside the dialogue box it's written that Parts inside your printer are...
You will need to get it serviced at an authorized Epson Repair shop as the parts that are at the end of service life are not user servicable. With the price of printers today it would be cheaper to buy a new one with updated technology than to try and have this one refurbished. Hope this helps.
Jul 19, 2009 | Computers & Internet
Epson C67 Printer
well generally the printer is always service-able, and parts that has reached the end of life are sometimes cheap, but OEM parts may be a little expensive.
here is a documentation for c67
http://www.epson.com.ph/epson/manuals/manual_download.htm?dc=1&mode=3&m=false&catid=1&pid=865
http://tech.epson.com.au/downloads/message.asp?platform=vista&techtips=techtips&EmailAdd=&MetricIDReturned=2592679&submit=Search+%3E%3E&sCategory=Inkjet&id=stylusc67
hope this helps out, if you have other questions just lemme know
Oct 22, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus CX1500
epson cx1500 reset porgram:
pop up for epson advises:
Parts inside your printer are at the end of their service life.
Feb 11, 2008 | Epson Stylus CX1500v Printer
Epson cx5500
I need some software for resetting epson cx 5500, please ?
Jan 07, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Printer
Duh, what does the error message say? Use the status monitor to get more info about the message. Chances are it will say "parts inside the printer have reached the end of their life..."
This means the waste ink counter has hit it's limit and needs to be reset after cleaning the pads.
This rescue kit will fix you up.
Oct 29, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
880 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
