Question about RCA P46924 46" Rear Projection Television
Picture bows on top and bottom of picture......
Hello i am very new to this forum but any help is apreciated. i found a Rca tv and the only thing wrong with it is the picture bows inwards on the top and the bottom .....where can i get info i need to fix this myself.....(service manuals,schematics....etc.) on the back of tv it says service no. = P46924YX5 MODEL = P46924 SERIAL NO = 051441559 CHASSIS NO = PTK195M2A i tried looking for the convergence menu also but it doesnt seem to have one......which puzzles me ....
  • erik rocha Aug 11, 2006
    THANKS SO MUCH.....I FOUND THE PART THAT YOU DESCRIBED BUT IT SAYS THAT THEY ARE NO LONGER MADE.....IF A SITE OFFERS SUBSTITUTE PARTS FOR THAT PART WHICH IN THIS CASE IS STK 730 130 CAN I USE IT OR WILL IT NOT WORK......SEE ONE SITE ACTAULLY OFFER THAT STK 730 020 PART AS A SUBSTITUTE......THANK YOU SO MUCH AGAIN FOR ALL YOUR HELP ....I REALLY APRECIATE IT....:)
  • erik rocha Aug 13, 2006
    You guyz rule.....so i found the part you guys explained....and replaced it......after a little while of cuss words ...(because i suck a soldering....)well i now how a big screen tv working like new.....so thank you so much and to think i only had to pay $8 for the part.........
    once again thanks....
    Problem Solver:
  • 13 Answers
Hi my asteamed coleage is correct in most cases.I have been a factory warrenty tech for rca since 1985. your set ctc 195 chassis has 2 boards 1 digicon board (digit convergence board) and 1 small convergence board called conver power supply) this board produces power to digicon board There is a pos 47volts and neg 47volts along with 15 volt supply ) i think if looking from back of tv (with back off) in the upper right corner you will see a small green board (4inc long by 2inch ) on that board is a silver metal piece going from top to bottom is a small black (kind of rectanggular black chip it has a clip ontop remove screw to see num on chip is 730-020 change that . as for your ques about customer convergence it's hard to find if you hit menu move down to vidio menu (you will get color,brightness and so forth but keep going down it will come to CONVERGENCE hit + key hope me and colleage helps fix tv from MILWAUKEE WIS HEY GOOD LUCK
Posted on Aug 11, 2006
    President:
  • 3,130 Answers
Your problem is the convergence IC'S. They have STK ###-### the # are numbers. You can get parts at http://partstore.com. If your not a tech and an experimenter or a handi person Pease be aware of the hi voltage inside these sets. Also be aware your going to need to unsolder and resolder the ICs in and from the printed circuit board. Good Luck
  • Larry  Dillon
    Larry Dillon Aug 11, 2006
    The first three are fine as long as they are the same.. Its the last three that will matter too. If the last three are 120 no you mshould not use an 020.. It will work but will not hold up long.. If the last three are 020 yes you can use the higher numbers to sub the lower as those numbers are the wattage output of .the IC
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Bowed at top and bottom
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Nov 10, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
RCA P46924 46" Rear Projection Television Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
