Question about Toshiba Portege M100 Notebook
Why my external USB CD Drive not booting up with Win XP at all. Checked the Bios Setting and has not got USB boot order
SOURCE: Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Posted on Jun 18, 2008
  • 148 Answers
SOURCE: boot from usb
Sounds like the boot order menu is what you have. Set the boot order menu to try other devices before the hard drive. (Example: CD/DVD drive, floppy; if present, USB devices, hard drive). You should have a default key for accessing the boot menu (usually f11 or f12). Hit this key and choose the USB option. Make sure the device you want to boot to is already connected before you turn on the laptop.
Posted on Mar 02, 2009
SOURCE: cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
Posted on Jul 07, 2009
  • 434 Answers
SOURCE: toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Posted on Jul 10, 2009
rockycleofas
  • 21 Answers
SOURCE: toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Posted on Nov 04, 2009
Cannot boot from cd rom
check out cd/dvd-writer.if any dust partikels clean with caned air.
Apr 22, 2013 | HP Compaq Evo D310 PC Desktop
I want to boot from a external hd with win xp in a hp pavilion 1129la
FlashBoot is the easiest product available to build an external boot disk. They provide a free demo version that can test before you pay for the program. FlashBoot can load many different operating systems but the program can also use FreeDOS, which has no additional licensing fees. If you have limited computer experience, this is the way to go.
May 23, 2011 | Computers & Internet
Hi, I've got a Toshiba Portege M205-S810 without CD-ROM drive. Only slots fro USB and SD Card. 1. How to boot up this tablet from SD card? SD card is empty. 2. How to make an image of my CD with Win XP...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=886254&ref=EV
If you want to use an external cd drive these are the ones that will work and only these..
The procedure is getting into BIOS settings (press F2 on start ) and on boot sector select the external drive as boot device )
If you want to boot from a SD card or USB memory stick ..than you have to make a boot-able one ..and from what I tried is kinda tricky to make a XP one..so you might consider to install windows 7 if the Ram memory is at least 1 G
But if you want to try ..here are some resources about how to make such a boot-able flash ..
here is for vista and 7 if you do nto have the cd drive ..use a virtual one like iso hunt
http://www.intowindows.com/bootable-usb/
Here is an xp ..and the tools for making a boot-able stick ..read carefully the instructions ..
it was made to install a asus eee which is also a non cd drive net-book
http://wiki.eeeuser.com/windowsxpusb
They recommend to select teh boot device on each restart ..I say to check the bios and see if the boot from usb is available and select it first boot device throughout the installation ..
Jan 27, 2011 | Computers & Internet
How to reformat my own computer?
You need the OS cd like XP,Vista,win 7,etc.. Then with the CD on the CD drive
1-start your PC.
2-at start up press F2
3-you will be enter in the BIOS setting
4-change the BOOT order to boot in to CD drive
5-when boot start you will be in the OS set up and follow the instructions.
Oct 14, 2010 | Computers & Internet
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Oct 21, 2009 | HP Compaq ProLiant DL380 G4 Server
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
I NEED TO LOAD WIN XP ONTO MY SONY VAIO NOTEBOOK WHICH IS THE CHEAPEST WAY .I HAVE AN AMACOM XTERNAL CD RE-WRITER BUT HAVE LOST THE POWER CORD can i load onto an external hard-dive and transfer to my...
assuming you have an xp license ...you can copy the winxp disk to a flash drive (usb) and boot from the usb drive to install windows.....you'll need to make the Flash drive bootable and you'll need to change the boot order in the viao's bios
Jan 03, 2009 | Computers & Internet
Toshiba Portege M100 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
