Question about Motorola Mobility RAZR V3i Cellular Phone
Not charging My E250 Is not charging i just put it on the charger i checked it and the battery wasn't charging
  • kami06 Oct 24, 2008
    I have tryed that
    Scholar:
  • 85 Answers
Dear
U should connect ur phone to PC with Mini USB Cable n Install Moto driver in Ur pc.
If Ur phone will charging well..............
than  may be ur charger dead...
If ur phone will not charge by pc connect......u should check ur phone to Moto Service centre...
Posted on Oct 24, 2008
    President:
  • 4,402 Answers
Either have bad battery or the plug in connection is loose or bad.
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
Nikon coolpix s205 wont charge
It probably wasn't the charger that was bad, but the rechargeable battery. They go bad over time.
According to the manual you need an EN-EL10 rechargeable battery.
Sep 25, 2012 | Nikon Coolpix S205 Digital Camera Red
Battery won't charge up
One or more of the cells in the battery may have died while it wasn't being used. LI-Po batteries are memory resistant but they can still develop one if they're left fully discharged too long or at a half charge too long. They require full charge\discharge cycles to keep them from developing a memory.
Feb 13, 2012 | ESKY 001336 20C 11.1V 800mAh Lithium...
Not charging
Well if your phone wasn't charging then probably the charger of your phone is having the problem, first of all you can try charging your phone using different charger. if you have the same issue after changing the charger then mostly the battery of your phone is dead.
Nov 05, 2011 | Nokia 5220 XpressMusic Cellular Phone
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
It will not power on, I plugged it into the computer, doesn't recognize it to charge the mp3 player. Even tried charging it with a dock and with another charger to no luck.
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery
Also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring problem) and put the back on.
Dec 19, 2010 | SanDisk Sansa e250 MP3 Player
How to charge my samsung e250 phone without a charger for it!!!!!!!!!!!!!!
Find a cable compatible for it to connect with the PC's USB port, such as e250 datacable and Infrared USB cable..By that way your phone will charge automatically. U can also use a desktop charger for it,where what you only have to do is remove your battery from your phone, insert it in the desktop charger, and that's it......u can charge.
A rate for this comment will be much appreciated. Thank you!
Sep 27, 2008 | Cell Phones
My Sansa e250 won't charge all the way!! Help me!
Sounds like the battery may have come loose in the back, so its not charging.
Take the 4 screws out, remove the battery. The put the battery back in and try charging it.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
