Question about Hardware & Accessories
Instructions for Nylex landscaper 6 irrigation timer
3 Suggested Answers
SOURCE: Instructions for garden watering system Hardie Irrigation
WIRES CONNECTION
Posted on Mar 08, 2010
SOURCE: Auromatic function on my T8845PV irrigation cotrol
Sounds like the timer clock motor has gone bad:
Open following links for troubleshoot and parts list:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Posted on Oct 06, 2011
I have an older Toro residential irrigation timer. I don't know the model number. How do I find the model number?
Call Toro Tech. help and describe the timer to them and they should be able to guess the model. Sorry, don't have Toro's number because I will not use anything made by Toro. If it was me I would replace the timer. .
Mar 28, 2014 | Toro-Irrigation 53794 Ecxtra 6 Zone Timer
Tip
Haste to stop waste!
Too often we let our irrigation systems go on without really making sure that the amount of water, the pressure, the radius and other settings are what our lawn or landscape needs.
This causes not only a great waste of water and money but it may also ruin our flowers and plants.
Therefore here are a few tips to transform a wasteful sprinkler irrigation into the effective system it should be, and to keep a healthy landscape, lawn or garden.
1. When to water.
Watering your lawn and landscape should be differentiated according to seasons.
During warm months (May to October) irrigation should be activated between midnight and sunrise, so to minimize the water that evaporates.
While during winter, plants and lawns should be watered during the warmer part of the day to prevent water from freezing on the landscape.
2. Don't drown your plants.
Keep an eye on your lawn while the sprinklers are on and monitor when the water starts dripping off the sides. This way you will know how long your sprinklers should be left active for, so that the plants may absorb the water without being overwhelmed.
3. Avoid daily, light watering.
4. When watering plants with deep roots, water well and deep, until about half inch deeper than the deepest roots, in order to encourage downward growth.
5. When watering on a slope do it gradually. Run your sprinklers every 3 hours circa and aerate to increase infiltration.
6. Check your sprinkler's efficiency once a month.
Check for damaged, leaking, clogged or stuck sprinkler heads and for constantly soaked patches of grass or soil to detect leakage.
Make sure that the water is sprayed all over the area and that new additions or plants that grew higher and larger don't block the spray pattern.
7. In seasons in which the temperature reaches 30/32 degrees Celsius remember to run your sprinklers 5 to 10 minutes in the afternoon to cool the area. It reduces the symptoms of summer patch disease.
8. Create water zones by putting together the plants that have similar water needs, and water them accordingly
9. Be careful when mowing. If your sprinkle heads don't retract underground after irrigation, apply small flags on them so that while mowing you see them better and avoid damaging them.
on Sep 09, 2013 | Garden
Need operating instructions
Go to Orbits web site and download instructions. Or since you have the least expensive timer known to man simply buy another one for $20.00 then you will have instructions and a spare timer. You will need it trust me.
Jan 23, 2014 | Orbit 6 Zone Automatic Irrigation Watering...
Moonrays noma landscape 9 hour power supply. cannot figure it out
You have the 9 hour 200 watt Moonray.
Copy following link to identify timer and see basic instructions by pushing button and cycling throught choices.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
Sep 23, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Lost instruction manual to set timer on oasis dundee 6 station sprinkler system
I can't locate any info on that timer. There is no timer that I can't figure out, I'm an irrigation contractor. Tell me what the face looks like or what buttons or dials are on it and I'll see if I can help.
Gary
Mar 11, 2011 | Garden
Schematic for installing garden drip watering syustem, includes timer and filter anf backflow
Good Afternoon, Frankborg9
I hope this message finds you well.
Here are the links to the manual for the hose runs and connectors
http://www.orbitonline.com/lib/media/DripMasterInstallationGuide.pdf
I do not know what timer you have, but you can get the manual by selecting that timer here:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Happy landscaping!
Chr
Dec 05, 2010 | Orbit Irrigation 61100 Dripmaster Layout...
Hardware & Accessories Logo
425 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
