Question about Alpine Car Audio & Video
2002 Lincoln LS cd player won't work after battery
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Try checking all of your fuses. Quite often a fuse blows when batteries or alternators are changed. There should be a fuse box in the engine compartment and another under the dash.
Posted on Feb 22, 2012
5 Suggested Answers
  • 5 Answers
SOURCE: 2003 Lincoln LS
i think you will most likely have to replace the factory unit. That problem is very common with cd changers. it's a mechanical issue. is it the cd changer on the stereo itself?
Posted on Oct 18, 2007
IB4G2008
  • 3587 Answers
that's a mechanical issue, actually...i'm assuming the rest of the cd player is working?
Posted on Feb 29, 2008
  • 5 Answers
SOURCE: my car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Posted on Sep 10, 2009
  • 10 Answers
SOURCE: Whenever we get our truck
The CD player is malfuntioning. Either the wiring is incorrect (A short, etc.) or just a heat problem. Good Luck to ya!
Posted on Jun 27, 2011
I have a bad battery in my 2002 lincoln LS. Will that cause it not to idle?
Does it die after you start it?
Your battery only gives the necessary "juice" to turn the starter, and crank. Your alternator takes over once it is running.
It is not your battery.
Mar 31, 2013 | 2002 Lincoln LS
CD won't load into the 6 disc changer.
Try loading your CD into the first slot of the magazine. Be sure the magazine is completely seated in the player
Mar 27, 2013 | 2005 Lincoln LS V8
Security light flashes and won't start 02 lincoln ls
How old & what condition is the battery,on an LS
they only seen to last 4.5 years
Try only one Ford- approved PATS key that is programmed & you know has been working & nothing else nearby, such as a key chain
with other objects
Does the LED indicator flash rapidly or glow steady for 3 seconds,
with key in Run or Start ,if so, you got problems & will need a scan tool to get the codes,not a code reader.
Does the starter turn over the motor?
Need at least 2 keys programmed to system
You got at least 7 fuses to check on 2 of the 3
junction blocks (fuses)
Nov 14, 2012 | 2002 Lincoln LS
2003 Lincoln ls v-8 cruise control won't engage. Light won't come on or anything when I hit the button. Everything else work fine.
My 2001 Lincoln ls cruise control will not work. Put in a new clockspring and that did not fix it. radio controls and horn work but the air bag light stays on continually after starting. The lights on the cruise side will go on an off -I have bought that part to replace but don't want to put on if that is not the problem.
Sep 12, 2012 | 2003 Lincoln LS
Cd in02 lincoln ls light comes on ( cd error ) wont work or eject ??
This can be from a couple things that caused this. Most the time and 99% of the time that causes this is the cd driver is dirty, which some times it just spits it out after error message comes on. AND in your case, it is staying in there spinning and reading error, and won't eject. One way that is possible to have this kick out is, to unhook battery, wait 5 minutes, and re- hook battery up, and sometimes it will trigger it to eject. If not, you do not want to start forcing something in there, it could cause more damage. You would then, i suggest , take it to car stereo shop as they have all kinds of methods to check it out and eject cd and figure out the fix method. Which could be as simple as a good cleaning, or cd itself was bad, or mechanism is screwed up.
I hope this helps Mike.
Oct 23, 2011 | 2002 Lincoln LS
Whenever i try to install a Cd in my Lincoln Ls 2002 it keeps telling me CD Error. Do you know why it may do that?
Thanks for choosing FixYa and welcome. Have you had the battery unhooked recently or have you lost power?
Apr 27, 2011 | 2002 Lincoln LS
2002 lincoln town car
pull the radio fuse out to see if the battery hold then check your radio/cd player for defects
Feb 22, 2010 | 2002 Lincoln LS
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
2002 Lincoln LS electrical systems down- won't start
Removed CD player for jammed CD. Reinstalled but car ignition and most electrical sytems won't operate although fuses appear OK. Don't know if it is related to the anti-theft system.When ignition is turned on, both tach and speedometer needles peg out and return to zero but no type of ignition
Apr 05, 2009 | 2002 Lincoln LS
Car Audio & Video Logo
366 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
