Question about Cameras
My computer does not recognize usb connection
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Posted on Feb 13, 2012
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Visioneer 8920, Can't get it recognized. Tried websight updates and still nothing. Also have hp 4200c same results.
You're saying that the computer is not recognizing the Visioneer 8920 and your HP 4200c when connected to it? if that is the case the problem here can be with the computer where its is connected and if this devices are connected via USB port bettery try connecting them on other USB port advisable connect it to the back USB if still not recognize try this on a different computer so we can check if they will be recognized...
Hope that helps......
Sep 30, 2008 | Office Equipment & Supplies
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
Motorola VE 440 computer does not recognize when connected w/USB
you might want to try it with a computer running Windows Vista - older operating systems will generally tell you that something is plugged into the USB port but will not allow you to access it as it does not recognize new software.
Mar 19, 2010 | Cell Phones
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
