Question about Digimate DGL32 32 in. LCD Television
How do I adjust volume when tv is frozen?
I recieved a shock when attempting to adjust the volume. My tv is frozen now. I am unable to power on/off, switch sources, change channels, etc. How do i correct this?
  • sbell2010
    sbell2010 Feb 12, 2012
    The tv has the three pronged male peice. Its plugged in properly. I tried unplugging and replugging to reset. didnt work
Unplug the television. Check to see if the plugs are polarized (one bigger than the other). Sounds like if the plug was plugged in the wrong way could cause what we call a hot chassis. The tv is not properly grounded, it appears to be a grounding issue.
Posted on Feb 12, 2012
I need to adjust volume on craig cht745 Only the
I don't think you can do what you imagine.
The Craig speakers are powered by the DVD receiver. That's how they're controlled.
Sep 06, 2014 | Televison & Video
Tv frozen
There is some fault with the 'start' circuit. It will be best to contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 14, 2013 | Televison & Video
The volume on my curtis mathis television is not working properly. the numbers are low but volume is high.
There is some fault with the control section to volume circuit. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Curtis-Mathis CM32010 TV
Volume control
not all remotes will program for all sets and if do may not have key features wanted or needed.
Jul 17, 2012 | LG Televison & Video
What does the sw level setting do?
hello.. the sw level is short for your subwoofers volume setting .when you use a subwoofer thats powered and connect it to your recievers sub out,this is than a way to adjust the subs volume from your seating position rather than only adjusting it from the back of the sub.. i recommend putting your subs volume(on the back of the sub itself) to midpoint and playing a bass heavy song or movie and adjusting the sub level on the reciever to how you like it.. enjoy
Sep 11, 2010 | Audio Players & Recorders
I want to be able to adjust the television volume and not have the home theater system over ride it
you wont be able to controll the volume from the tv to controll your reciever, but you can have sound come from both, with different controlls.
on your tv (not sure what you got) in your tv menu select : TV SPEAKER TO ON, and then the sound will come out your tvspeakers as well as the reciever, but to be brutally honest you dont want to do that.
that will cause an echo effect and will drive you nuts
May 04, 2009 | Audio Players & Recorders
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Digimate DGL32 32 in. LCD Television Logo
Top Digimate Televison & Video Experts
Jaime Hernandez
Jason Morris
Computer Repairing
Computer Repairing
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
