Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool untimate care II won't spin/agitate.......
It will pump water out. Any help apprecitated.
  • Whirlpool Master
  • 2,671 Answers
For anyone looking at this now,check the motor coupling,common problem with direct drive washers.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
if you can hear the motor but the washer doesn't do anything ,check the coupling,this is what engages the ******,if the coupling is good then you have a bad ******
Posted on Apr 29, 2012
  • Sal De Apr 29, 2012
    don't know why it blocked transmission
  • 750 Answers
Welcome gonecamping
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
In the Whirlpool it could be this.
Or a door latch
Posted on Oct 24, 2008
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum won't spin - especially when full of clothes. Whirlpool Ultimate Care II LSQ9564J Top Load.
Does it spin without anything in it?
Does it agitate?
Does it pump out the water?
If you said Yes to all of these Im sorry to say this you probably burnt out the clutch.
If it doesnt agitate maybe you will be lucky and you only need a coupler.
If you over load it often and wash large items you probably burnt out the clutch. This is an expense repair. You may want to consider a new washer.
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY ULTIMATE CARE II WASHER DOES NOT SPIN, IT DOES EMPTY THE WATER AND IT DOES AGITATE, ANY SUGGESTIONS?
Hello Friend, Your solution is simple. If your machine agitates and pumps water then all you need to install is a new lid switch. A very simple task. Happy to help, Tim.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool agitator not working!
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Jan 09, 2009 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II motor overheating
this type of whirlpool washer has the water pump on the other end of the motor. if you are sure that you installed the drive coupling correctly then it is most likely something in the pump.
you can unhook the pump and run the washer and see if it works OK.
If it does then go get a new pump
May 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal De
