Question about HP Computers & Internet
How to remove the bottom of a laptop to tighten the power supply outlet
  • HP Master
  • 5,660 Answers
Doesn't work that way, verlinewms
Depending about what manufacturer, and model of laptop, we are 'talking' about here;
1) The DC Power Jack may be soldered directly to the motherboard,
OR,
2) It may have wires coming from it, that are inside a sleeve, and plug into a connector on the motherboard.
(DC Power Harness)
With the example stated in 1) above, you have to Completely disassemble the laptop, down to the bare motherboard in your hand.
(FOLLOWING Anti-Static precautions. Advise use an ESD wrist strap, and connect the alligator clip to a good ground source. Average cost is around $3 to $6. ALWAYS follow Anti-Static Precautions when working on a computer )
With example 2) above you disassemble the laptop, from the top down. Stop when the Palm Rest Cover is removed, in most cases.
[ Display Assembly removed. Then LED power strip above Keyboard. Then Keyboard. Then Palm Rest Cover. (Also referred to as Top Cover ]
Let me separately show you a basic example, for styles 1) and 2) above, using an HP laptop;
1) http://powerjack.us/index.php?main_page=product_info&products_id=8684&zenid=37ec82c9742dc233abe7f0e68d967ac7
With this style, the DC Power Jack has to be properly un-soldered from the motherboard, and a new one properly soldered in.
Click on the photo with the four views of this DC Power Jack.
Look at the view to the left/middle.
In relation to how this jack should be mounted on the motherboard, it is now laying on it's right side.
The pins, or prongs, on the left side in this view, go down through the motherboard.
A) The solder connections of those pins, (Prongs), can be cracked.
This makes an intermittent connection, which will soon go to no connection.
This style of DC Power Jack uses a Center Pin, and a surrounding metal shell. The shell is in segments.
The Center Pin is the most susceptible part, of this style of DC Power Jack,
to damage. It's just a large pin riveted to the back of the jack.
(Connected to a metal frame at the back)
This is just a short primer, of how to replace this style of DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
More info,
http://www.laptoprepair101.com/laptop/2008/10/28/fortify-damaged-power-jack-connection-in-laptop/
2) http://www.insidemylaptop.com/hp-g62-compaq-presario-cq62-disassembly/
Read, and observe the photos, but stop for a minute on Step 22.
The Yellow arrow is pointing to, the direction that the DC Power Harness plug, has to go in order to remove the plug from the connector, on the motherboard.
Looking at a photo of that DC Power Harness, will make more sense with the above photo, in Step 22,
http://www.laptoppowerdcjack.com/product_info.php?language=en&currency=USD&products_id=268
See the White long connector at the end of the DC Power Harness? (Towards bottom of photo)
Three Red wires, and two Black wires going to it?
In Step 22 this connector is next to the tip, or point, of the Yellow arrow.
The other end of the harness, or the DC Power Jack itself, is all the way to the Right.
It's sitting in a little U shaped channel, formed out of the plastic of the Bottom Case.
With this style you disassemble the laptop far enough down, (Top Cover, or also stated as Palm Rest Cover), to access the harness.
Then simply unplug it, plug a new one in, and reassemble the laptop.
(Remember - Anti-Static Precautions)
Look on the bottom of the laptop for the Model Number.
For HP it is the Product Number that is needed.
This is in a white Service Tag. P/N = Product Number
Post it back in a Comment.
(Caution! S/N = Serial Number. DO NOT post this on a public forum. Only give to an authorized HP dealer, or repair shop)
I may be able to give you a link to a free Service Manual, and would also like to post some pointers, if I may.
Regards,
joecoolvette
Posted on Feb 15, 2012
  • joecoolvette
    joecoolvette Feb 15, 2012
    EDIT:
    This article details disassembly of an HP dv6000 series of Notebook PC.
    Should be added to 1) above,
    http://www.insidemylaptop.com/disassembl...
  • 807 Answers
You will probably have to strip it right down to get the motherboard out.
The socket might need resoldering. if you are not technically minded you would be better off taking it to a repair shop. You can do more damage than good if you are not careful. Youtube have a lot of videos about disassembling laptops / pc's if you want to do it yourself.
Posted on Feb 13, 2012
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
MBP screen hinge tightening
Hinges are located under the lcd screen and go into the bottom of the base or palmrest. You'll need to remove the strip that is right above the keyboard that normally houses the power button on most laptops. The strip might be secured by screws that are on the bottom of the laptop. Be careful removing the strip, most times there is a cable attached to it under the bottom. Once the strip is removed the hinges are exposed. Just take a phillips head screw driver and tighten them.
Mar 27, 2012 | Computers & Internet
I left my computer and when I came back it was off and the battery was plugged in the outlet. I restarted it and it worked for a minute or two and then closed again. When I pressed the power button again,...
It might be possible that your power adapter died. But before reaching this conclusion remove your adapter from the outlet and the laptop. Examine for any broken connections and if none, try plugging it back in. Also try using your adapter on a different outlet.
Hope this helps.
Mar 13, 2011 | Sony Computers & Internet
Acer Extensa 5620: The power supply jack is loose when you plug it into the laptop. Sometimes it will provide power and sometimes it will not (orange battery light on front of laptop goes on & off)....
System check
1. estimate the extent of damage, possibly requires entire board replacement housing the extension power supply modulators, possibly due to physical damage on contact.
2. Aslo check the battery life since could determine the possibilty of substituting power chord from currrent outlets with batteries
The device would not connect to power outlet without a properly functioning battery installed. A depleted battery could not be replaceble by connecting a source out power outlet. each parts of the power complement the entire process of achieving computer experiece.
Consult a technician insisting the replace the entire power system of battery and ac adapters and also fixing damages on the mother board may be contributing to power leakage
Dec 02, 2010 | Acer Extensa 5620 Notebook PC
How to replace a waterpump on a 2001 olds alero 2.4 cam
Water pump is driven by timing chain idler and is mounted on the rear of the timing chain housing. Disconnect the neg. battery cable. Drain cooling system. Disconnect oxygen sensor connector.
Remove upper exhaust manifould heat sheild. Remove exhaust manifold brace. Remove lower exhaust manifold heat sheild. Loosen manifold to exhaust manifold spring loaded nuts. Remove radiator outlet pipe to water pump coverbolts. Disconnect exhaust pipe from manifold.
Pull down on the exhaust pipe to disconnect it from exhaust manifold bolts. Disconnect outlet pipe from oil pan and transaxle. If equipped with manual tranaxle, remove exhaust maifold brace. Leave lower radiator hose attached and pull down on radiator out look pipe to disengauge from water pump. Leave outlet pipe hanging.
Lower vehicle. Remove exhaustmanifold to cylinder head nuts. Remove exhaust manifold to cylinder head nuts. Remove manifould. Remove timing chain front cover. Remove timing chain tensioner. Remove bolts bolts securing water pump cover to cylinder block. Remove water pump to timing chain housing nuts. Remove water pump attaching nuts. Remove water pump and cover assembly. Separate componets as necessary.
WHEN INSTALLING WATER PUMP MAKE SURE YOU FOLLOW THE TIGHTENING SEQUENCES THAT AFFECT SEALING. My frist one I messed up and broke the pump so becarful.
Installation
If cover was separated from body during removal, join this componets with a new gasket and hand tighten bolts. Apply bearing grease to splines of water pump drive. Set body and assemble into position.
Install and hand tighten bolts securing cover to cylinder block. Install and hand tighten bolts securing cover to cylinder block. Installand hand tighten nuts securing body to timing chain housing. Lubracate outlet pipe "O" ring with antifreeze. (I use RTV) Connect outlet pipe. Install and hand tighten bolts. Tighten bolts and nuts to specification in the following sequence. I'll ad the torque spec. at the end but this is where if you tighten out of order something will break.
pump assembly to timing chain housing nuts.
pump cover to pump body bolts
pump cover to cylinder block bolts (Bottom Bolt First)
outlet pipe to cover bolts
To complete installation reverse removel procedure.
Torque specs are 19 in. or 26mm all except water pump cover bolts which are 124 in or 14Nm
I never torque the bolts just make sure there done in the right order.
Oct 19, 2010 | Oldsmobile Alero Cars & Trucks
My laptop is not switcghing on
Is there enough charge on the battery? Does the problem occur when the AC/DC supply is plugged into the back of the laptop? The problem could lie with the battery, the power supply, or the motherboard. First, take the battery out of the laptop. It should be on the bottom of the laptop. Leave the battery out of the laptop. Next, plug the power supply into the laptop, and plug the power supply into a known working outlet. If the laptop comes on, then the problem lies with your battery. It will need replaced. If it doesn't come on, then it could be a bad power supply or motherboard. I would try a new power supply before replacing the motherboard.
May 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Was using the laptop (dv6426us) and it just cut off. Was plugged into outlet with power supply, no warning messages prior to that. Now it will not power on at all, no lights, no beeps, nothing. If I unplug...
First, measure the voltage coming out of the power supply. If it is good (specs will be on the power brick itself.) then this sounds like a short on the motherboard. To eliminate all else, remove anything that is removable (hard drive, CD/DVD and RAM). Leave the battery out also. Plug in the power supply and see if it beeps. If not, you have a bad motherboard. If it does beep, replace the ram. At that point, you should be able to see POST. If you get nothing, it is the ram. Keep adding until the problem resurfaces. The last item added is the culprit.
Good luck.
Aug 12, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Charger for E1705 beeps and no green light
You are describing a classic wiring short circuit. Either the cables of your power supply or the jack on the laptop itself are damaged and need to be repaired or replaced as soon as possible to avoid permanent damage. There is no logical reason it would work only in certain outlets, that is probably just coincidental to the way you have the cable running while plugged in to each outlet.
Your power supply has two cables, the side leading to the AC outlet is removeable and easily replaced but the side leading to the laptop's jack is not. Start with the AC plug. Leaving everything from the 'brick' to the laptop in a stable position, gently flex the AC cable until you see evidence of the short (usually a break in the wire, possibly chewed by the dog or snagged on the edge of a desk). If so, replace the AC wire. If not, try the same with the laptop side of the brick. If so you usually should replace the entire power supply unless you are real handy with a soldering iron.
If moving the position of the two power supply cables doesn't identify the short, you must suspect the laptop's jack of being loose. This is worst of all because the laptop motherboard has to be removed to gain access to resolder the jack, a professional job that will run probably $100.
Dec 28, 2008 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
Power BOX supply cord problem or hardrive problem?
Check these settings first. In a clear spot on the screen where no icons are, right click and go to properties, box opens and at top should list from R to L, themes-desktop-screensaver-appearance-advanced. click on screensaver, close to bottom click on power, another box should open, click on power schemes, make sure it's set to portable/laptop, and at bottom make sure settings for plugged in are are set to never. If it's not that then you have a bad power supply cord, or a bad power supply unit in laptop. If it's new and under warranty take it in and have replaced if not warrantied then will cost you about 100-150, just a guess!! hope this helps. But it sounds like the supply cord making the beeping noise might be bad. Make sure it's plugged all the way in as well.
Nov 17, 2008 | Toshiba Satellite M40-S417TD Notebook
Drainage
Turn off the hot and cold water supplies and remove the power supply cord from the outlet. Remove the lower front panel by removing three torx screws, one located at the lower left corner, lower center, and lower right corner. The panel removes easily. Located at the bottom center of the cavity is a large ivory colored filter with a turn cap. Get a shallow container or alot of towels, and slowly turn the slotted cover to the left a little at a time until no water runs.  Remove the filter and any debris that may be inside. Wash and dry the filter and replace, tightening the cover securely. Replace the lower panel, turn on the water supplies and plug in the power supply.  This should solve your problem and also relieve any standing water in the drum following a wash.  You may want to do this every 3 months or so as this is an easy fix
Sep 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Computers & Internet Logo
125 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
