Question about Ovens
De dietrich ER1
The error code ER1 appears on the timer display
4 Suggested Answers
applianceboy
  • 77 Answers
SOURCE: ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced. if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! good luck.
Posted on Sep 28, 2007
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
SOURCE: De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Posted on Dec 11, 2009
De Dietrich DOD788B is not switching on. None of the digital buttons work except for the timer, but the clock is on.
ovens can sometimes need a time set on the clock, it dose not need to be the right time but it must be at a time ie not flashing
Dec 11, 2016 | De Dietrich Ovens
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
Dec 11, 2009 | Ovens
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Ovens Logo
37 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
