Question about LG Washing Machines
LG WM-16225FD error code LE
Machine will fill with water, But does not oscillate properly, comes to a halt then displays code LE
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
SOURCE: LG WM-2277 displays LE
I have exactly the same problem. The motor is covered by a 3 year warranty. You'll have to pay for labour. I will not buy any LG product in the future. Its junk.
Technician said the motor requires replacing. I believe its a computer module error. Some people were advised to unplug the machine for 2 hours and allow the computer to reboot! This does not sound like a mechanical issue. Whatever it is the machine is poorly developed and completely overpriced. Customer service is non-existent. Website is cumbersome and unhelpful. looks like a money grab to me by Lucky Goldstar (yes, LG is the new name for Goldstar, a low end appliance manufacturer of the past)
Disatisfied Customer (5 weeks out of warranty)
Richmond Hill
Ontario
Posted on Oct 21, 2008
SOURCE: LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Posted on Dec 19, 2008
  • 77 Answers
SOURCE: door wont lock
hi, it is probably the lock mechanism that is faulty, you need to get it changed, hope this helps!
Posted on Feb 10, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Tip
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG washing machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
I get a message le or ue error and machine stops
Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
May 30, 2011 | LG WM-2277HW Front Load Washer
Water still in machine says LE on display
LE error code means Locked Motor Error.
Sometimes this can be cleared by unplugging then plugging back in the machine. If this does not clear it you have a faulty component.
This usually failure of a component called the Hall Effect Sensor which may need to be replaced.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
Error codes
Here are the common error codes for the LG machines.
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
UE
IE
LE
PF
FE
PE
CE
TE
SE
HE
DHE
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Our wm-16225fd does not spin/drain.I have fitted a
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 15, 2009 | Washing Machines
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG front load machine with LE code and no spin
LE is a locked motor error. Not to worry as 95% of the time this is just a bad hall sensor (motor position sensor). It is very easy for a technician to replace and the cost is very small.
Hope this helps, please rate my solution.
Oct 25, 2008 | LG WM-2077C Front Load Washer
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
