Question about Kenmore 63672 Convection/Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
I have a Kenmore 721.804 microwave. During the middel of the night it started beeping and displayed 66:66. Unplugging it resets the problem for a few hours, but then beeps again.
It does work fine otherwise (heats and turns).
  • rossleed Oct 24, 2008
    Had it unplugged for one whole day, but did not reset the problem
  • Anonymous Mar 31, 2014
    It is loud and obnoxious and I want it turned off
  • Kenmore Master
  • 19,396 Answers
Try first unplugging power cable for ten minutes, and see if it clears the error.
Posted on Oct 24, 2008
  • Ginko
    Ginko Oct 24, 2008
    Error codes on Kenmore microwaves are in format F1 E3 etc. 66.66 is not an error code, that is a faulty control panel.
    If the problem persist you will need to have the control assembly replaced.
    You can find parts here.
    Or here.
  • Ginko
    Ginko Oct 24, 2008
    That is because the contro panel board is faulty, or the ribbon cable that connects the panel is bad or misplaced, likely the oven must be taken apart and the part replaced.
I have a Galaxy 721. microwave. There is a beep that sounds every minute and the microwave is not being used. I am stumpped! How do I stop the beeping?
Sounds like someone activated the timer function. See if you can find the timer function in the menu, then turn it off.
Dec 31, 2014 | Microwave Ovens
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Kenmore Microwave -SE- code
I have the same problem with my microwave and i cant fix it help?
May 10, 2010 | Kenmore Microwave Ovens
Microwave will not start
We ended up taking the microwave out of the built in cabinet and, unplugging it and plugging it in again just to see if it would reset itself and that worked- at least for now!
Jan 08, 2010 | Kenmore Microwave Ovens
Microwave starts beeping, four times then displays SE
Sounds as if it may be getting hot look at the back and under the unit there will be a grid of sorts sometimes at the back and//or the bottom or side/s of the machine check to see if this is free of dust etc if not clean and try again remember microwaves can give a nasty bite//please switch off and unplug first..
Dec 29, 2009 | Microwave Ovens
Been cursed with the 666's
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Sep 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kenmore 63672 Convection/Microwave Oven Logo
605 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
